'75 1.8 914 No Start? Please help., No Spark |
Maximum1302 |
Mar 23 2009, 04:23 PM
Newbie Group: Members Posts: 14 Joined: 23-March 09 From: Las Cruces, NM Member No.: 10,196 Region Association: None |
(IMG:style_emoticons/default/driving.gif) Hello all. Just recently purchased my dream car, a Nine-Fourteen. Its a 1975 1.8 with fuel injection. I have encountered a no-start problem. I was driving it and it was running fine and now it will not start. There is no spark! I know its getting fuel and that everything is mechanically sound, but there is no power to the coil. The coil itself is fine I just replaced it and Im sure it works alright. Where do I look now? I checked my fuses and they are all good. (IMG:style_emoticons/default/WTF.gif) Please help! I love my car! Thanks
904svo |
Mar 23 2009, 04:31 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
make sure there is power on both sides of fuse#9 with the key on if there
is no power your switch may be bad. If there is, this goes to the relay board pin #8 comes out to pin #7 to the coil. |
Maximum1302 |
Mar 23 2009, 04:40 PM
lol sorry Im no electrical master, but what you said about that fuse made me wonder because I followed one of the wires from that fuse over to the stereo, and it wouldnt start after one of my friends was fiddling with the stereo. So which switch could be bad? The ignition switch? Im confused as to how it happened because I dont see how messing with the stereo could make the car not have spark but then again it ran before he messed with it and when he was done... kaputt
So.Cal.914 |
Mar 23 2009, 04:55 PM
Where was power taken from for the radio? If taken off any power source, it could have been for the ignition and blew the fuse at the panel. Get a Continuity Tester, you'll be glad you did.
Edit: Where's my manners... (IMG:style_emoticons/default/welcome.png) |
Maximum1302 |
Mar 23 2009, 04:59 PM
Well, the radio looks stock to me. I know it is wired through the ignition because you cannot turn on the stereo without the key on. Also all the fuses are good on the fuse panel under the dash. Are there any other fuses I sgould check? Thanks.
904svo |
Mar 23 2009, 05:31 PM
Well, the radio looks stock to me. I know it is wired through the ignition because you cannot turn on the stereo without the key on. Also all the fuses are good on the fuse panel under the dash. Are there any other fuses I sgould check? Thanks. The fuses may look good but they could have dirty contacts and are not making conection. Check with a volt meter for voltage on both sides. That fuse is the switch power fuse. |
jc914 |
Mar 23 2009, 06:03 PM
Member Group: Members Posts: 289 Joined: 15-September 08 From: Miami, Florida Member No.: 9,548 Region Association: South East States |
(IMG:style_emoticons/default/welcome.png) you are on the right path to fixing the problem
ejm |
Mar 23 2009, 07:14 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,692 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
QUOTE There is no spark! ....... but there is no power to the coil. Did you check for power at terminal 15 on the coil or are you assuming there is no power because there is no spark? QUOTE and it wouldnt start after one of my friends was fiddling with the stereo QUOTE I know it is wired through the ignition because you cannot turn on the stereo without the key on Does the car have points ? or a pertronix which may have fried with the key on, engine not running |
Maximum1302 |
Mar 23 2009, 07:28 PM
Well I have not checked terminal 15 for power, but the coil is good so should I still do it anyway? And the car has a regular distributor with points. And I checked for spark where the coil plugs into the dizzy, so Im pretty sure the coil isnt getting power.
zonedoubt |
Mar 23 2009, 07:51 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
There is good L-jet troubleshooting info here: http://manuals.type4.org/ljet/
I went through this top to bottom when diagnosing various starting problems after re-installing the fuel injection system on my 1.8. |
Maximum1302 |
Mar 23 2009, 08:38 PM
Would a clicking wiper relay have anything to do with it? The thing that is weird is I had JUST driven the car. Walked away for a while, and my buddy fiddled with the stereo and that was it. When I came back, no spark.
Maximum1302 |
Mar 24 2009, 09:29 AM
I checked out that website for L-Jet troubleshooting, but I could not find anything that had to do with my problem. Sorry guys guess Im just an idiot
6freak |
Mar 24 2009, 01:33 PM
Would a clicking wiper relay have anything to do with it? The thing that is weird is I had JUST driven the car. Walked away for a while, and my buddy fiddled with the stereo and that was it. When I came back, no spark. LET YOUR BUDDY FIX IT (IMG:style_emoticons/default/slap.gif) THEN BEAT HIS ASS...LOL (IMG:style_emoticons/default/welcome.png) GOOD LUCK |
McMark |
Mar 24 2009, 01:45 PM
Turn the key on and check for power at the coil (term. 15), yes, even new coils need power to work. (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/cool.gif) (IMG:style_emoticons/default/wink.gif)
Then pull out your Haynes manual and look at the wiring diagram to find the connection on the relay board that goes to the coil. Check for power there with the key on. (Hint: it's pin 7) Then check for power at the connection between the relay board and the fuse panel with the key on. (Hint: it's pin 8) Then check for power on the appropriate fuse with the key on. (Hint: it's fuse 9) Report back here with your results and I'll tell you exactly where your problem is. If you don't have a Haynes manual or a multimeter, you need both items NOW and in the future. So get them. |
MartyYeoman |
Mar 24 2009, 01:48 PM
Senior Member Group: Members Posts: 1,519 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Maximum1302 |
Mar 24 2009, 09:59 PM
McMark, thanks for the tip, unfortunately I will not have time to check til the morning. I have a Multimeter, however I do need to go get the hanes manual!
Marty, Okay I lied, I didnt test for spark like that, I made my friend Arthur do it... well actually he did it without me asking lol. I learned my lesson doing that test on my Super Beetle ... oops (IMG:style_emoticons/default/blink.gif) |
Maximum1302 |
Mar 25 2009, 10:45 AM
Hey, when you guys say the "relay board" and to test pin 7 and 8... is this the right place to be testing?
CliffBraun |
Mar 25 2009, 02:30 PM
Member Group: Members Posts: 252 Joined: 26-April 06 From: San Luis Obispo,ca Member No.: 5,933 Region Association: None |
Hey, when you guys say the "relay board" and to test pin 7 and 8... is this the right place to be testing? That would be the relay board. There are copies of the factory manual floating around, it can be a bit daunting, but is amazingly useful to have. PM me if you're interested. |
Cupomeat |
Mar 25 2009, 02:50 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Just a little something I thought I'd add.
The stock radio does not run on Ignition power, so it should play without the key being on. That being said, I think the fuse path is a good one and the Haynes manual is worth its weight in multimeters there. However, a good check of all the fuses in the fuse block is a fine way to start this troubleshooting exercise. I know I found the current flow diagrams on line for the 1.8 before, but will post the link when I re-find them. Good luck and I love my 75 914 l-jet. It is surprisingly reliable. |
Maximum1302 |
Mar 25 2009, 03:38 PM
Hey guys I got some new news. I fiddled with the plug on the relay board and now the multimeter shows that there is power to the coil, when I gound it to the engine. Hovever when I ground the multimeter on the negative terminal of the coil, there is no reading on the multimeter. This indicates a bad ground right? There are 3 wires plugged into that side, one is the condensor for the points... but there are two others... a white one and a black one... what now?
Lo-Fi Version | Time is now: 18th May 2024 - 06:32 PM |
