The *ULTIMATE* M-Caliper Upgrade, Perfect for 914-6's |
Eric_Shea |
Mar 26 2009, 06:02 PM
I get so excited about this stuff…
I guess it goes back to the years when I remember having a 911 with the lowly T-struts (which I actually love now). I remember searching high and low for a caliper upgrade but around every corner there was no true bolt on upgrade for the 3" spacing. Although I no longer have any cars with the 3" struts, I finally found a "real" upgrade, a "real" bolt on solution that meets my entire criterion for an acceptable swap from the stock M-Caliper. Here's the low-down: These Brembos have a 3" bolt spacing and the exact same offset as the M-Caliper. This means they'll simply bolt right on. When I say bolt on I mean... all the way. They even fit with the standard dust shields. The fluid inlet is aimed right up at the tab on the strut for a direct in. They have the same 48mm piston as the M-Caliper, S-Caliper and the later A-Caliper. What's cool about this is, they are the later "cup" type piston with no knock-back mechanism to deal with. The cup design offers better cooling with much more surface area than the standard M and S-Caliper pistons. Also nice is the fact that this won't throw off your fluid dynamics with your current Master Cylinder. Again, Bolt on! The pad size is much larger than the M-Caliper pad. They are the same width as the A and S-Caliper pads but not as tall... (only slightly, like 2mm or so). If anyone is familiar with the BMW 320i pad size, these are the same. Another nicety, as I mentioned that these add up in all areas as a true bolt-on upgrade is; with this basic pad size (which has been proven with the S-Caliper and A-Caliper) there is no over stress of the standard 20mm rotor which obviously lived on all 911's through 1983. They weigh in a full 4lbs lighter than the M-Caliper so there goes a good chunk of un-sprung weight (yes, they're aluminum!). Did I say "Bolt on upgrade!"? You simply take your M-Calipers off and stick them on the shelf (in a plastic bag of course) for posterity sake, bolt these on, bleed the system (you know you should do that this year anyway) and you'd be good to go! These calipers are sold on an "As-Available" basis. Here's what you get: * Freshly anodized caliper cores (clear or black available). * Freshly plated fasteners. * New seal kits and caliper ½ seals throughout. * Pistons reconditioned with new heat resistant paint These calipers will be like new when they arrive at your door. Be sure to ask about Speed-Bleeders and Porterfield pads (and rotors and bearings and…) http://www.pmbperformance.com/catalog/item...552/6862358.htm |
underthetire |
Mar 26 2009, 07:20 PM
(IMG:style_emoticons/default/drooley.gif)
Holy crapola. Those are, those are, oh man. Thats just porn! |
ConeDodger |
Mar 27 2009, 11:50 AM
Apex killer! Group: Members Posts: 23,581 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I will take two. One for each side please! (IMG:style_emoticons/default/biggrin.gif)
PeeGreen 914 |
Mar 27 2009, 12:37 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
sixnotfour |
Mar 27 2009, 12:38 PM
914 Wizard Group: Members Posts: 10,429 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Get in line.
Eric_Shea |
Mar 27 2009, 01:31 PM
Out of 11 pair, I have one pair left.
PeeGreen 914 |
Mar 27 2009, 01:42 PM
Wow, those went fast. Would these be good for the rear? The rear is the only ones I would need now Since I have some of your other hady work up front (IMG:style_emoticons/default/biggrin.gif)
Eric_Shea |
Mar 27 2009, 03:48 PM
I'd stay with what you have... much better bias.
euro911 |
Mar 27 2009, 10:54 PM
A little rich for my blood (IMG:style_emoticons/default/headbang.gif)
By any chance, does this mean that there might be 11 sets of M's for sale soon? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/happy11.gif) |
charliew |
Apr 2 2009, 11:22 PM
I wonder what german or european car made about the same time as the 911 that these came on? A guy can probably redo some aluminum calipers but it will take a lot to equal Eric's. The anodizing is neat on the aluminum to stop corrosion.
Eric_Shea |
Apr 9 2009, 11:29 PM
***Sold Out*** of the first run.
BKLA |
Apr 9 2009, 11:56 PM
Really old member Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest |
6freak |
Apr 10 2009, 08:21 AM
Maybe im blind ..but i didnt see a price anywhere in the post ...
ConeDodger |
Apr 10 2009, 11:30 AM
Maybe im blind ..but i didnt see a price anywhere in the post ... The price is on the PMB Website linky in the first post. But if you have to ask... (IMG:style_emoticons/default/biggrin.gif) |
6freak |
Apr 10 2009, 11:36 AM
I see said the blind man talking to the deaf lady on the telephone.. Thanks Dodger |
ConeDodger |
Apr 10 2009, 11:47 AM
I see said the blind man talking to the deaf lady on the telephone.. Thanks Dodger One bright day in the middle of the night two blind boys went out to fight back to back they faced each other drew their swords and shot each other (IMG:style_emoticons/default/biggrin.gif) |
6freak |
Apr 10 2009, 11:57 AM
I see said the blind man talking to the deaf lady on the telephone.. Thanks Dodger One bright day in the middle of the night two blind boys went out to fight back to back they faced each other drew their swords and shot each other (IMG:style_emoticons/default/biggrin.gif) I have a few more but there not very P.C so i will share them with you at WCR09.. (IMG:style_emoticons/default/beerchug.gif) |
Michael N |
Apr 20 2009, 11:33 AM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
Finally installed and working fantastic. Thanks Eric for the fantastic product. I like the bling factor with the Mahles....
Eric_Shea |
Jul 7 2009, 08:37 AM
Looks awesome Michael,
Five more sets arrived yesterday. Three are spoken for. Two left. |
Eric_Shea |
Jan 29 2010, 02:43 PM
Two new sets available at this time.
Lo-Fi Version | Time is now: 11th May 2024 - 06:54 PM |
