Bucking problem |
Bucking problem |
StratPlayer |
Mar 31 2009, 09:07 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
I just woke up my car from a long winters nap. Car fired right up and I let it warm up before I took her for a spin. I noticed before I put the car away for the winter that I was starting to experience some bucking when I realease the clutch in first gear. Well the bucking is still there, would this be a sign of a bad pressure plate or what would cause this problem. Will be pulling the motor soon to check on a few things since this motor is a new rebuild.
Shade Tree |
Mar 31 2009, 12:00 PM
Member Group: Members Posts: 260 Joined: 18-December 08 From: Springfield, Oregon Member No.: 9,860 Region Association: Pacific Northwest |
Bad seals letting oil get on the flywheel....clutch chatter. Or it could be a broken front motor mount.
McMark |
Mar 31 2009, 01:04 PM
(IMG:style_emoticons/default/agree.gif) Check for broken front motor mounts. Applying some pressure with a floor jack under the motor can tell you. If the motor moves a bunch relative to the bar, then your front mounts are gone.
Lo-Fi Version | Time is now: 26th May 2024 - 09:12 PM |
