application of anti-sways.., Install where none had been |
914werke |
Mar 30 2003, 11:59 PM
"I got blisters on me fingers" Group: Members Posts: 10,102 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/icon13.gif) Ok, need some help. I have the original frt. & rear bars, hardware & bushings. Am planning to install on my street 73 2.0.
My front A arms already have the U tabs so Im good there. My question is, while the general area where the thru the body bar is obvious, How do you locate ..exactly.. the holes for the collar & how big should the center hole be? In otherwords is there a specific orientation of the 3 mount bolts to clear anything on the back side? Any BTDT? On the rear I assume you just attach the links & swing the bar up to the point it contacts the trunk floor? Bolt or weld the tabs of the mounts to the floor & your good? Or is ther a measurement to mount those that will once applied preload the bar? Am I making sense? (IMG:style_emoticons/default/icon14.gif) Rich |
Brad Roberts |
Mar 31 2003, 12:37 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Sold.
Send me the dash: SSI C/O Brad Roberts 20 Pamaron Way Novato, Ca. 94949 When you set the triangle into the recess... it will self locate. Just make sure you have it flat. Repeat on the other side. They dont give you enough room to screw it up. Dont worry about stiction... your probably still running the OE rubber mounts. Let me know if you want adjustable drop links for your stock bar (75$ shipped) all new parts with left and right hand threaded heim joints. B |
Lo-Fi Version | Time is now: 27th May 2024 - 02:50 AM |
