application of anti-sways.., Install where none had been |
914werke |
Mar 30 2003, 11:59 PM
"I got blisters on me fingers" Group: Members Posts: 10,072 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/icon13.gif) Ok, need some help. I have the original frt. & rear bars, hardware & bushings. Am planning to install on my street 73 2.0.
My front A arms already have the U tabs so Im good there. My question is, while the general area where the thru the body bar is obvious, How do you locate ..exactly.. the holes for the collar & how big should the center hole be? In otherwords is there a specific orientation of the 3 mount bolts to clear anything on the back side? Any BTDT? On the rear I assume you just attach the links & swing the bar up to the point it contacts the trunk floor? Bolt or weld the tabs of the mounts to the floor & your good? Or is ther a measurement to mount those that will once applied preload the bar? Am I making sense? (IMG:style_emoticons/default/icon14.gif) Rich |
914werke |
Mar 31 2003, 12:55 AM
I see. So the hole has to be just large enough for the bar to pass though. Will a hole saw work on the rail ? And yes I am running the OE mounts, but they'r new! Should I be using a different bushing? The entire setup came off my now departed 74 SE creamsicle, (burnt to the ground (IMG:style_emoticons/default/sad.gif) )
In fact Geoff got the orange bumper! Thanks. I have to figure out packing for the cap. |
Lo-Fi Version | Time is now: 19th May 2024 - 12:11 AM |
