application of anti-sways.., Install where none had been |
914werke |
Mar 30 2003, 11:59 PM
"I got blisters on me fingers" Group: Members Posts: 10,070 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/icon13.gif) Ok, need some help. I have the original frt. & rear bars, hardware & bushings. Am planning to install on my street 73 2.0.
My front A arms already have the U tabs so Im good there. My question is, while the general area where the thru the body bar is obvious, How do you locate ..exactly.. the holes for the collar & how big should the center hole be? In otherwords is there a specific orientation of the 3 mount bolts to clear anything on the back side? Any BTDT? On the rear I assume you just attach the links & swing the bar up to the point it contacts the trunk floor? Bolt or weld the tabs of the mounts to the floor & your good? Or is ther a measurement to mount those that will once applied preload the bar? Am I making sense? (IMG:style_emoticons/default/icon14.gif) Rich |
Brad Roberts |
Mar 31 2003, 01:01 AM
The arrow was to point out where on that flat spot you need to make a access hole. This car had a factory bar so... I didnt need to cut a access hole in that little frame rail area.
I use a cutoff wheel and make a square hole below the the hole for the bar. I recommend drilling all 4 holes (3 bolt holes and one hole for the bar) before you cut the access hole for the 3rd lower bolt/nut combo. Use a hole saw to cut the main bar hole... make it big so in case you want a bigger bar later.. you dont have to redo it. B |
Lo-Fi Version | Time is now: 18th May 2024 - 10:05 PM |
