> Door gaps are not even any more!, Now what???
FourBlades
post Apr 4 2009, 01:31 PM
Post #41
From Wreck to Rockin
I was test fitting my doors before painting them and noticed this:
Driver side.
Passenger side.
FourBlades   Door gaps are not even any more!   Apr 4 2009, 01:31 PM
FourBlades   The gaps were ok before I welded in my Engman kit....   Apr 4 2009, 01:35 PM
ConeDodger   The gaps were ok before I welded in my Engman kit...   Apr 4 2009, 01:48 PM
SirAndy   I have also heard of putting bracing in the door ...   Apr 4 2009, 02:02 PM
SirAndy   Now WTF do I do??? Put the car on a lift, open t...   Apr 4 2009, 02:05 PM
FourBlades   > Put the car on a lift, open the doors and use...   Apr 4 2009, 02:12 PM
FourBlades   I did use a brace bolted to the upper seat belt mo...   Apr 4 2009, 02:09 PM
SirAndy   Any measurements I could do using simple tools to...   Apr 4 2009, 02:36 PM
Richard Casto   I did use a brace bolted to the upper seat belt m...   Apr 6 2009, 09:19 AM
JazonJJordan   I did use a brace bolted to the upper seat belt m...   Jul 29 2009, 11:03 AM
Bartlett 914   I feel your pain. I repaired my 75 when I got it i...   Apr 4 2009, 03:11 PM
FourBlades   Thanks man...did you have any trouble getting your...   Apr 4 2009, 03:26 PM
sww914   It will be very difficult or impossible to find an...   Apr 4 2009, 03:48 PM
FourBlades   According to wikipedia, steel expands .00000645 in...   Apr 4 2009, 04:03 PM
Wes V   I've got a question for the author of this str...   Apr 4 2009, 05:45 PM
FourBlades   Wes, This is a really good question. I went out ...   Apr 4 2009, 06:14 PM
drive-ability   I had that happen as well when I installed some st...   Apr 4 2009, 06:43 PM
r_towle   The A pillar, at least the part that the door hing...   Apr 4 2009, 07:29 PM
FourBlades   Rich, Thanks for the suggestion. Have you tried ...   Apr 4 2009, 07:40 PM
r_towle   Yes I have done it. Push on the outer rear b-pilla...   Apr 4 2009, 07:53 PM
FourBlades   OK, cool, I will try it tomorrow. Thanks....John   Apr 4 2009, 08:23 PM
Bartlett 914   :popcorn:   Apr 5 2009, 11:08 AM
charliew   I would think the passenger side will be easier to...   Apr 5 2009, 11:28 AM
FourBlades   Charlie, Thanks for the suggestions. I was hopi...   Apr 5 2009, 11:52 AM
horizontally-opposed   I am pretty sure I read on some forum that a guy ...   Apr 6 2009, 10:10 AM
Richard Casto   I am pretty sure I read on some forum that a guy...   Apr 7 2009, 06:54 AM
charliew   About thirty years ago I torch welded the floors i...   Apr 5 2009, 12:13 PM
Wes V   I'm trying to get my mind around this whole ...   Apr 6 2009, 09:08 AM
McMark   In my experience, this is the problem, John. I r...   Apr 6 2009, 09:56 AM
andys   When I welded my Engman kit, I measured my door ga...   Apr 6 2009, 10:39 AM
6freak   I was test fitting my doors before painting them ...   Apr 6 2009, 10:42 AM
FourBlades   Mark: I did a fair amount of seam welding on mine...   Apr 6 2009, 11:52 AM
horizontally-opposed   How did your guy know where to jack up your car? ...   Apr 6 2009, 12:33 PM
Wes V   I think something to think about would be to do on...   Apr 6 2009, 03:01 PM
Wes V   Fortunately, he knew what he was doing and was ab...   Apr 6 2009, 03:03 PM
horizontally-opposed   Fortunately, he knew what he was doing and was a...   Apr 6 2009, 03:39 PM
FourBlades   Mr. C: I was wondering about that too. If I neede...   Apr 6 2009, 11:56 AM
6freak   Mr. C: I was wondering about that too. If I need...   Apr 6 2009, 12:30 PM
FourBlades   Slim line hinges may work....hmm.. Great, windows...   Apr 6 2009, 02:56 PM
burton73   John, Your post was freaking me out all weekend. ...   Apr 6 2009, 03:20 PM
FourBlades   Bob: Your door gap looks pretty good. Sounds lik...   Apr 6 2009, 05:58 PM
r_towle   So, To use a hydraulic unit to spread the door, y...   Apr 6 2009, 06:33 PM
FourBlades   Rich, Which part of the rear door jamb do you res...   Apr 6 2009, 06:52 PM
r_towle   outer edge so you are pushing against the fender (...   Apr 6 2009, 07:14 PM
charliew   Adding the material will fix the small door but I...   Apr 6 2009, 07:18 PM
Wes V   It sure would be nice if somebody stepped up with ...   Apr 6 2009, 07:56 PM
FourBlades   Richard, I think I made the same mistake when I p...   Apr 7 2009, 07:44 AM
Richard Casto   John, I think part of the problem is that if I kn...   Apr 7 2009, 08:13 AM
charliew   Welding never spreads any structure. It will alway...   Apr 7 2009, 10:08 AM
Richard Casto   Welding never spreads any structure. It will alwa...   Apr 7 2009, 12:55 PM
charliew   The fact that the engman kit covers the top and in...   Apr 7 2009, 01:12 PM
Bartlett 914   Heating the driver side bottom might help close j...   Apr 7 2009, 01:30 PM
charliew   Heating the driver side bottom might help close ...   Apr 8 2009, 12:18 AM
McMark   John, I've used a PortaPower between the front...   Apr 7 2009, 05:48 PM
atomix8   I realize I'm thread hijacking, AND pulling ou...   Jul 27 2009, 07:54 PM
tracks914   Yours looks easy to fix. Your door is too low at ...   Jul 28 2009, 08:46 PM
atomix8   Yours looks easy to fix. Your door is too low at...   Jul 29 2009, 05:42 PM
r_towle   Yours looks easy to fix. Your door is too low a...   Jul 29 2009, 07:12 PM
rick 918-S   [quote name='atomix8' post='1196947' date='Jul 29...   Jul 29 2009, 08:16 PM
- Lo-Fi Version Time is now: 31st July 2025 - 10:03 AM
