Help with emission control hose conections, Installed 2.0 motor in 72' where do hoses go? |
old9one4 |
Apr 13 2009, 09:55 PM
Newbie Group: Members Posts: 35 Joined: 1-March 07 From: Sunnyvale, CA Member No.: 7,574 Region Association: Northern California |
Rebuilt 2.0 motor and installed in 72' 1.7 car.
73' 2.0 motor has carburators and car has 72' 1.7 emission plumbing. Pictures or diagrams would be a great help. Thanx. |
SLITS |
Apr 14 2009, 07:18 AM
Lezsee ... you would have the following left:
1.) Fuel evaporative system 2.) Crankcase vent 3.) Head vents #1 ... Will have two hoses ... one connected to the impeller housing to supply air to the charcoal canister and the return hose which would go to an air cleaner (fuel fumes to be sucked into engine to be burnt) #2 & 3 ... probably should be tied together and sent to a breather box mounted on firewall, as high as possible to promote drainback. If an outlet port is available on the breather box, pipe it back to the air cleaner too! Anyway, that's how I would do it. |
Lo-Fi Version | Time is now: 16th May 2024 - 02:43 AM |
