motor transaxle mounts, my 1975 2.0 - bouncing badly |
jimkelly |
Apr 15 2009, 12:02 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i thought for sure the rubber motor mounts had gone bad - i jacked up the car and started the engine - and realized it was at least one rear one was bad - luckily i had two new 911 type laying around - installed them and engine idles with no bounce now : ) lucky for me as this is the limit of my mechanical abilities, well this and installing gas in the tank : ))
Attached thumbnail(s) |
type47 |
Apr 15 2009, 01:20 PM
(IMG:style_emoticons/default/smilie_pokal.gif) so, now you're ready for Hershey (IMG:style_emoticons/default/driving.gif)
dflesburg |
Apr 15 2009, 01:34 PM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
next time use new bolts and nuts... good grief.
jimkelly |
Apr 15 2009, 01:53 PM
good eye - rusty nuts and bolts - busted : ))
grade 8 stainless would have been sweet ?? |
Apr 15 2009, 03:07 PM
this is the limit of my mechanical abilities You are missing the big cup washers that prevent your tranny from sliding off the mounts! (IMG:style_emoticons/default/huh.gif) #37 in the diagram ... (IMG:style_emoticons/default/smash.gif) Andy Attached image(s) |
jimkelly |
Apr 15 2009, 03:48 PM
dang it : )
they of course were not there when i started the project or else - i PROBABLY -would have put them back on : )) i'll have to put up a set at the hershey swap next week. thanks brother andy jim |
veltror |
Apr 15 2009, 05:42 PM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
I personally would not use stainless bolts on this but high tensile ones, I know it is not high stress but there you go stainless where there is little stress in volved.
Lo-Fi Version | Time is now: 16th May 2024 - 03:58 PM |
