| zeezee |
Apr 19 2009, 02:20 PM
Member ![]() ![]() Group: Members Posts: 115 Joined: 16-October 08 From: san ramon, ca Member No.: 9,651 Region Association: Northern California |
I found two badly deformed exhaust seals when I pulled the pipes off the manifolds.
Any tips or tricks to making sure the seals and pipes seat correctly? I'm considering a small drop of glue/sealent to stick the copper seal and pipes together properly - hoping this helps with proper alignment when I bolt the pipes into the manifold. |
zeezee Replacing exhaust seals Apr 19 2009, 02:20 PM
Al Meredith Always file the part of the exhaust that contacts ... Apr 19 2009, 05:57 PM
solex I anneal the gaskets prior to fitting/installation... Apr 19 2009, 06:12 PM
3d914 I second solex! Apr 19 2009, 07:20 PM
zeezee Will do - Thanks.
Searching for "anneal... Apr 20 2009, 02:03 PM
Cap'n Krusty If you're gonna file the pipes, you MUST file ... Apr 20 2009, 02:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 07:05 PM |
