Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Using a dingle berry hone tool
Rich |
dbgriffith75 |
TheGrif ![]() ![]() ![]() Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest ![]() |
I'm not sure what you mean by "dingle berry hone tool" but as long as you use a lubricant (I've always used diesel) it's not difficult. Try to keep your drill running at about mid speed and use smooth, even strokes up and down the cylinder and it should turn out just fine. An even "criss cross" pattern means you did it right.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,785 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Not in years but, yea. Does your existing cylider have any pitting? If so, forget it. You cannot resize the cylinder w/ a honing tool. You can just clean it up. Keep moving the tool in & out while it is turning. I used 5w or "3-in-1" brand oil to lubricate the honing process. When satisfied take a 3/8" wood dowel, split the end of it about 1", slip the end of a red cotton shop rag in the slit and wrap the rest around the dowel. Now chuch the dowel in your drill and run it in the same motion as the honing tool was used. Take your time!
Why the rag?
What is the purpose? Rich |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
IME, and in the opinion of most good machinists I've asked, a ball hone isn't worth the price of the material it's made of. Use a real hone, or go home. If you must do this, be sure you thoroughly flush and scrub the cylinder with HOT soapy water. A toilet brush works fine here. That goes for all honing, BTW. The Cap'n
craig downs |
Senior Member ![]() ![]() ![]() Group: Members Posts: 769 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California ![]() |
I strongly agree with the cap'n a ball hone is the worst because it just follows what ever condition the cylinders are in.
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
I have used a ball type hone on many normal re-ringed motors that are not high performance, from 345 scout motors to 350 chev truck motors to vw's and all I was trying to accomplish was to deglaze the cylinder for the new rings and old pistons. I think it works fine. If the motor is already at the machine shop then I will pay them to hone the cylinders only if they are also boring them for a larger piston. The ball hone is only for deglazing.
I have used a ball type hone on many normal re-ringed motors that are not high performance, from 345 scout motors to 350 chev truck motors to vw's and all I was trying to accomplish was to deglaze the cylinder for the new rings and old pistons. I think it works fine. If the motor is already at the machine shop then I will pay them to hone the cylinders only if they are also boring them for a larger piston. The ball hone is only for deglazing. De-glazing is all I will be doing on this motor. Rich |
Cap'n Krusty |
Remember, proper honing of air cooled cylinders is done in a fixture so they are held round. The Cap'n
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
ball hone is fine for a home re-ring. remove ALL teh carbon ridge first. if they dont clean up in 15 sec, they will need a real hone job as capt described
Lo-Fi Version | Time is now: 30th August 2025 - 06:42 PM |
