VIN of a 1972 914-6 |
Gustl |
May 6 2009, 04:40 AM
914 enthusiast & historian Group: Members Posts: 11,492 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
could you show me some photos of various cars,
to be exactly, I'm interested in the VIN that's stamped in at the top of the passenger side fender I mean, not in the VIN itself, but in the stars in front of and behind the VIN what does it look like - exactly as an example I show you the VIN of a 1970 914-6 I'd like to see if there's a difference to the MY'72 six ... (IMG:style_emoticons/default/bye1.gif) Gustl |
dr914@autoatlanta.com |
May 6 2009, 07:29 AM
914 Guru Group: Members Posts: 7,832 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
should be exactly the same. The two 72 models as well as the 72 916 have the exact look as the 70 model 914-6 models.
could you show me some photos of various cars, to be exactly, I'm interested in the VIN that's stamped in at the top of the passenger side fender I mean, not in the VIN itself, but in the stars in front of and behind the VIN what does it look like - exactly as an example I show you the VIN of a 1970 914-6 I'd like to see if there's a difference to the MY'72 six ... (IMG:style_emoticons/default/bye1.gif) Gustl |
Gustl |
May 6 2009, 08:39 AM
George, would you be so kind to take photos of them, where we can see the whole VIN including both "stars" ??
recently I've seen a MY'72 VIN between two "stars" that looked different ... more this way (sorry, just a hand-drawing from MS Paint): Attached image(s) |
Gustl |
May 6 2009, 08:54 AM
The two 72 models as well as the 72 916 have the exact look as the 70 model 914-6 models. maybe you should really check this ...? your comment made me check my 916 files and I found out that the VIN of both blue 916 is between two "stars" like in my hand-drawing ... so it might be the correct look any proof of other MY'72 VINs (914.2.43.0xxx or 914.2.33.00xx) would be highly appreceated (IMG:style_emoticons/default/bye1.gif) Gustl |
smg914 |
May 6 2009, 02:55 PM
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
I found this on Armando's site. Not the best example because the stars are not defined very well. Actually only the star at the end is visible and even that one you can't see it very well.
Gustl |
May 6 2009, 03:09 PM
thanks Steve - it's pretty clear that the star at the end is the same style than on my hand drawing
at least it's definitely not the MY'70 style ... |
May 6 2009, 04:16 PM
Resident German Group: Admin Posts: 41,609 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
DEC |
May 7 2009, 11:45 AM
Senior Member Group: Members Posts: 630 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany |
mel reckling |
May 9 2009, 06:05 AM
Member Group: Members Posts: 107 Joined: 28-November 07 From: north royalton, ohio Member No.: 8,385 |
Gustl |
May 9 2009, 08:01 AM
Not a good pic, but from my 72. and it's clearly visible that it's the same kind of star - thanks (IMG:style_emoticons/default/thumb3d.gif) and thanks to the others as well (IMG:style_emoticons/default/pray.gif) |
May 12 2009, 07:19 AM
I misread your post thought that you meant the style of the plate and stamping. The 71 models have a regular five point star on each side of the number the 72 models and the 916 have the "starburst" type star with the multi lines.
should be exactly the same. The two 72 models as well as the 72 916 have the exact look as the 70 model 914-6 models. could you show me some photos of various cars, to be exactly, I'm interested in the VIN that's stamped in at the top of the passenger side fender I mean, not in the VIN itself, but in the stars in front of and behind the VIN what does it look like - exactly as an example I show you the VIN of a 1970 914-6 I'd like to see if there's a difference to the MY'72 six ... (IMG:style_emoticons/default/bye1.gif) Gustl |
Lo-Fi Version | Time is now: 2nd May 2024 - 01:06 PM |
