Getting rings to seat |
JJ914 |
May 10 2009, 12:59 PM
Big JJ Group: Members Posts: 90 Joined: 30-December 04 From: Augusta GA Member No.: 3,374 Region Association: None |
Need advice on getting rings to seat in my new 2.0. It is still smoking after it gets warmed up. It has about 500 miles on it now. The motor has total seal rings in it and I am thinking that they or one of them has not seated. I have Rotella oil in now but it didnt help much. Any advice on what I could do to help.
Thanks |
ConeDodger |
May 10 2009, 02:23 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I've never heard of anyone using Total Seal Rings in a Type IV but when I have used them on Datsun motors it is critical that the gaps be opposing or they will never seat. Maybe Jake will weigh in on this but I would bet he has tested Total Seal Rings and has a reason he doesn't use them on everything...
Al Meredith |
May 10 2009, 05:58 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
Jason, If you want me to re-ring that motor let me know. My son has never liked total-seal , from experience and I only used them because they were already there. Taking the top end off is not a big project. With the engine out it should take 1/2 day. Al
ConeDodger |
May 10 2009, 07:46 PM
Just to add to my earlier comment, 500 miles is a bit early yet. You do need to wind her out really well and let her come back down a few times to get them to seat. Again, I have not had a problem using Total Seal on Datsun L series engines in the past but the Type IV is a different animal all together.
I would bet they were installed correctly if Al built that motor. I don't know him but by reputation. The compression ring has a second ring inside it that expands to give a better seal in theory. The second ring must gap 180 off from its mother ring. I have never asked Jake why he doesn't use them but if Blake doesn't like them, I would bet they have been tested... I think both Blake and Jake are at the track this and both of the previous two weekends... |
Jake Raby |
May 10 2009, 08:07 PM
11 times I have attempted to use them in a TIV engine. 10 times I have failed. This post has been edited by Jake Raby: May 10 2009, 08:11 PM |
May 10 2009, 08:12 PM
11 times I have attempted to use them in a TIV engine. 10 times I have failed. cant say never...it did work once...(IMG:style_emoticons/default/laugh.gif) |
ConeDodger |
May 10 2009, 08:48 PM
JJ914 |
May 10 2009, 08:55 PM
OK I have driven the crap out of the engine and if they havent sealed yet they arent going to I guess. So I guess it times to re-ring. Other than the smoke it runs great and doesnt leak, but smoking isnt good. Sounds like the total seal arnt going to work out. Al I will send you a PM.
Jake Raby |
May 11 2009, 09:53 AM
Put the car in second gear.. Take it to redline and hold it there for a second or two then leave the car in gear and do not put your foot on the clutch. Allow the vehicle to "push" the engine all the way down to about 20 MPH, then pin the throttle to the floor again and hold it there all the way to redline again...
Do this process 4 times without intermission.. If the rings don't seat then, they'll never seat. Disclaimer: This is what I'd do- it is not a recommendation for what you should do in case something should explode.. |
May 11 2009, 10:01 AM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Disclaimer: This is what I'd do- it is not a recommendation for what you should do in case something should explode.. (IMG:style_emoticons/default/biggrin.gif) |
JJ914 |
May 11 2009, 08:16 PM
Ok I have tried to seat the rings as Jake suggested a few weeks back and it didnt help. So its tme to re-ring. Will it hurt the engine to keep driving it till I can pull out the engine. It only smokes when it warm and comeing off idle. I to miss some of the good weather time for enjoying the top off (IMG:style_emoticons/default/biggrin.gif) .
yeahmag |
May 11 2009, 08:36 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Out of curiosity, what color is the smoke?
May 11 2009, 08:40 PM
yes it will hurt the motor.
Fuel is getting into the oil. Rich |
904svo |
May 11 2009, 08:43 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Do you have Webers 40 on it, if you do what kind of gas millage are you getting?
Al and I found a problem with the choke circuit where it was running RICH !!! If you are running rich the rings will never seat! |
hot_shoe914 |
May 11 2009, 08:45 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Need advice on getting rings to seat in my new 2.0. It is still smoking after it gets warmed up. It has about 500 miles on it now. The motor has total seal rings in it and I am thinking that they or one of them has not seated. I have Rotella oil in now but it didnt help much. Any advice on what I could do to help. Thanks Drive the car up to the Talimena run this weekend and let me have it for the weekend while you drive my limited. If they aren't seated by the time I get done (IMG:style_emoticons/default/driving.gif) the (IMG:style_emoticons/default/post-2-1117899824.gif) out of it, you may as well rering it for sure. p.s. If I blow it up I will not be held responsible due to the fact if it blows, it wasn't put together right in the first place. Mine haven't blown yet. (IMG:style_emoticons/default/aktion035.gif) |
JJ914 |
May 12 2009, 10:26 AM
Hey there,
Ok I did have 40IDFs on it but I took them off and installed a prog weber just to see if that was a issue(no change). The smoke is a whiteish color, it dosnt smoke at all till it gets warmed up good, then it does it coming off idle then clears up till back to closed throttle. I got with Al and he said to try and get them to set a little longer and if not we will re-ring it. I will change the oil in it again incase there is some fuel in it and then put some hard miles on it (good times, yea). |
yeahmag |
May 12 2009, 10:47 AM
That sounds like the oil rings didn't seat. Have you noticed any oil level changes? Does the oil smell like gas when you "sniff the dipstick"?
JJ914 |
May 12 2009, 08:39 PM
The oil level has dropped a little but not to much, No fuel smell in the oil. The gas milage seems ok, I havent check it officially. What would if any be the best kind of oil to use to help with the problem?
type2man |
May 12 2009, 09:15 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
I'd change the oil, do a compression test, and put another 500 miles on it. Then check the oil level again and see if it has gone down. If the rings dont seat, you will have some gas in the oil which might give you an inaccurate reading of the oil level. Have you ruled out the possibility of bad valve guides or excessive blowby since you just had the engine redone?
JJ914 |
May 12 2009, 09:48 PM
The heads where rebuilt and look really good, so I hope they are not the trouble at this point. I will try and do a compression test too.
Lo-Fi Version | Time is now: 17th May 2024 - 07:19 PM |
