installing factory oil tank right now - filler neck question, doesn't go in straight?? |
Mike D. |
May 13 2009, 06:32 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
Not sure but probably have the 911 oil filler neck. Anyway when I go to put it in, the dip stick tube hits the oil screen inside the tank and the cap ends up at an steep angle. This can't be right?!?
Is there a hole in the screen I should find with the tube? working on this right now if anyone has the answer... THANKS |
boxstr |
May 13 2009, 06:44 PM
I just put one in a six the other day, and I didn't have to find any holes for the dipstick tubre. It went in easily and I just tightened the clamp on the hose between the tank and filler neck.
CCLINOILMEUP |
Mike D. |
May 13 2009, 07:03 PM
FOUND IT! ok, so there is a hole in the screen, cap still isn't perfectly straight but way better than before...
Thanks for looking See you guys on FRI.!!! |
JmuRiz |
Sep 27 2010, 01:35 PM
914 Guru Group: Members Posts: 5,429 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Bringing back this thread:
So you can use a 911 filler neck on a 914/6 factory-style oil tank? Would you need to change the dip-stick out for a 914/6 specific one, to get the correct depth markings? Same with the oil filter console...the one on a911 tank can be used on a 914/6 tank, right? Thanks, edit: whoops, a little more digging and I think I found the answer in this old thread: http://www.914world.com/bbs2/index.php?sho...ller++neck++911 |
Lo-Fi Version | Time is now: 20th May 2024 - 04:44 PM |
