Pin holes in the head sealing surface..., Can I run as-is, or should they be welded up? |
jhadler |
Jul 1 2009, 03:28 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Thanks Jake. Yeah, you're right, it's a big unknown. I'm in a dilemma though. I don't know how much a -proper- repair of this head will cost, and am very tight for funds these days.
edit - I know... Buy cheap, buy twice... -Josh2 P.S. Jake, can you give me a call sometime? I think you still have my number. Thanks! |
jhadler |
Jul 1 2009, 03:37 PM
FYI, the measurements that I have right now are as follows:
(these are without a head gasket) Combustion chamber volume: 59.5 cc's Deck Height: 0.016" Intake valve to top of piston: 0.220" Exhaust valve to top of piston: 0.330" Piston ring end gaps all right around 0.020" The pushrods and valvetrain geometry were checked and stock pushrods gave me spec lift and all geometry looks good. -Josh2 |
Jake Raby |
Jul 1 2009, 03:51 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Josh,
I haven't forgotten about you but I don't have your number.. I am actually away from the shop this week, but can call you when I return. |
jhadler |
Jul 1 2009, 04:52 PM
HAM Inc |
Jul 1 2009, 05:14 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
This head had a pin hole in the same area. Money was tight so no repair was made with the hope that the stud would contain the cylinder pressure. Made it 20 minutes! It blew the stud and you can see what happened after that! While it's true that this engine had quite a bit more compression than yours probably does, and while it is also true that I have seen a lot of heads that ran for a very long time with pits in this area, it only takes one experience like this for me to take a stand against risking it. My earlier statement that you probably wouldn't have a catastrophic failure may not be such good advise. Proceed with extreme caution! I think the best advise I could offer would be to fix it right. If that means putting the project on hold and saving some money then so be it. |
HAM Inc |
Jul 1 2009, 05:16 PM
BTW, this head landed on my bench in the past month. Very recent failure!
Jake Raby |
Jul 1 2009, 05:45 PM
BTW, this head landed on my bench in the past month. Very recent failure! I also told the Owner of that head that it should be retired.. One day people will listen.... (probably not, they all think our experience is BS and we are just trying to sell them something) Break enough shit and you'll learn the limitations. No one here as broken more shit than I have. |
jhadler |
Aug 27 2009, 03:39 PM
Well, since the motor is coming out and the heads are coming off after 1.5 hrs of break in time, it might be telling to see if the pin-holes caused any subsequent damage.
-Josh2 |
brant |
Aug 27 2009, 05:02 PM
914 Wizard Group: Members Posts: 11,731 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Josh,
please update me obviously its not a good thing... but why is it coming out again? sorry man brant |
gothspeed |
Aug 27 2009, 05:46 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
If it is a 2.0 head .... replace both of them with new Raby heads ...... then send the two bad heads to me for proper disposal ....... (IMG:style_emoticons/default/shades.gif)
jhadler |
Aug 27 2009, 06:03 PM
If it is a 2.0 head .... replace both of them with new Raby heads ...... then send the two bad heads to me for proper disposal ....... (IMG:style_emoticons/default/shades.gif) I'd love to put some raby heads on there... You buyin'??? -Josh2 |
jhadler |
Aug 27 2009, 06:05 PM
Josh, please update me obviously its not a good thing... but why is it coming out again? sorry man brant In the course of trying to find out what was going on with the oil temps, it became apparent that the deck height in the build was too low. No point in risking it when a few shims can resolve that. Just pull the motor, pull the heads etc. add shims, reassemble... Just a major time demand on time I don't have these days. It'll get done though... -Josh2 |
brant |
Aug 27 2009, 11:10 PM
How did you decide ?
detonation? brant |
Lo-Fi Version | Time is now: 20th September 2024 - 04:21 PM |
