> Reverse Idler Gear, Tips for proper Clearance ?
2-OH!
post Mar 1 2004, 02:34 PM
Hanyes manual says to set the clearance between the Reverse Idler and the sliding 1st shift gear to 1mm. The only problem is that the shaft for the Reverse Idler gear is roll pinned inside the rear cover so it's not possible to measure the distance, with the case on or without removing the pin...
Must be another way...Need some advice...
2-OH!
2-OH!   Reverse Idler Gear   Mar 1 2004, 02:34 PM
Bleyseng   I used a deep dish socket that was the same diamet...   Mar 1 2004, 08:05 PM
- Lo-Fi Version Time is now: 1st May 2026 - 05:21 AM
