Are dash switches the same for all years?, What years are compatible with a 73? |
FourBlades |
May 21 2009, 10:50 PM
From Wreck to Rockin Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
I tried to find this information by searching but no luck. This must have been answered by someone before. What are the differences in the headlight, hazard, fog lamp, steering column, and other dash switches? I really just need to know what years would be compatible with a 73 wiring harness. My switches were all missing and I have a set from a 71 wiring harness but I am not sure they will work. This wiring loom is giving me a headache... John |
SLITS |
May 21 2009, 11:31 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
1.) Headlight switch ... Two versions .. 10 pin and 11 pin ... your '73 would have more than likely used an 11 pin. The '71 would be a 10 pin.
2. Hazard, foglamp, heated rear window are all the same except for the color of the the insert on the foglamp and heated rear window. 3.) Windshield wiper switch ... on the dash for a '71 and part of the steering column switch on a '73. 4.) Cigarette lighter .... the same 5.) Heater controls ... believe they are the same except for trim. |
Steve Snyder |
May 22 2009, 03:36 PM
Member Group: Members Posts: 241 Joined: 10-June 08 From: Graham, NC Member No.: 9,158 Region Association: South East States |
I think there were also two versions of the hazard switch: a 6-pin (+ground) for the '70-''72 MY and a 7-pin (+ground) with a little diode soldered between two of the pins on the '73-'76 MY cars.
Lo-Fi Version | Time is now: 2nd June 2024 - 07:31 PM |
