Altenator testing, anyway to test an altenator |
hot_shoe914 |
May 24 2009, 03:04 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Anyway to test an altenator without it being on the car? I know, dumb question.
Drums66 |
May 24 2009, 03:11 PM
Not a dumb Question?...take it to your local auto parts
most of them test alts and starters (Gratis) hope that helps you! (IMG:style_emoticons/default/smoke.gif) |
So.Cal.914 |
May 24 2009, 03:15 PM
What he said.
hot_shoe914 |
May 24 2009, 03:21 PM
Tried that already. Autozone and NAPA both said their equipment wasn't designed to test the Bpsch altenator which is regulated externally.
Donald |
stepuptotheMike |
May 24 2009, 03:49 PM
medium pimpin Group: Members Posts: 565 Joined: 4-September 06 From: Charlotte, NC Member No.: 6,769 Region Association: South East States |
You may have to go a little bit old school and find a generator/alternator repair shop in your area. I had to do the same with mine a couple of weeks ago. FLAPS couldn't test it with their rig and rebuilt unit would have been about $110. Generator shop in the area tested it, replaced the brushes and bearings for about $35. Check the yellow pages.
Mike |
PanelBilly |
May 24 2009, 03:52 PM
914 Guru Group: Members Posts: 5,805 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Check the junk yards in your area. Likely one of them has a rebuild business as part of the operation
type47 |
May 24 2009, 05:54 PM
Is there Advance Auto Parts in TN? Mine in VA has the connections to test an alt, not to say all AAP's can.
hot_shoe914 |
May 24 2009, 06:21 PM
Lo-Fi Version | Time is now: 13th May 2024 - 05:40 AM |
