Replacing the o ring on the oil filter mount, anyone had any experience with this? |
dereko88 |
May 27 2009, 10:07 PM
Newbie Group: Members Posts: 7 Joined: 10-May 09 From: Pullman, Wa. Member No.: 10,353 Region Association: Pacific Northwest |
Hey, I'm not an expert on cars or engines at all but I do know that my 914 has got a leak on the oil filter mount and an o ring needs to be replaced. Does anyone know what it takes to replace this and how much it might cost if I brought it to a professional?
Thanks for the help and if anyone has pics that'd be great! |
tomeric914 |
May 28 2009, 06:55 AM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
(IMG:style_emoticons/default/blink.gif) Assuming that this is a 914-4, the O ring is part of the oil filter. Replace the oil filter!
Also check to see if the O ring from the previous filter isn't stuck to the filter mounting surface. I've seen that happen when the O ring wasn't oiled before installation. |
URY914 |
May 28 2009, 07:18 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,520 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
The filter has a flat rubber gasket, not a true O ring. The oil you see on top of the filter is probably come from somewhere else like the oil pressure sender above the oil filter.
Lo-Fi Version | Time is now: 11th May 2024 - 08:39 AM |
