> Cooling "mister", ...oil cooler and heads
yeahmag
post Jun 23 2009, 04:08 PM
I've been thinking about this for a long time and only found one partial thread on it. It seems to me that an "intercooler style" mister could be very beneficial on the track to help control oil and head temps.
While I had no head temp issues at Willow, my oil temps did rise to the point I pulled off. I was thinking a simple mister introducing water mist in to the fan or directly above the oil cooler could be a trick way to deal with temp spikes.
Anybody done this before?
-Aaron
yeahmag   Cooling "mister"   Jun 23 2009, 04:08 PM
yeahmag   Looks like a lot of fun could be had here: http://...   Jun 23 2009, 04:46 PM
r_towle   Use a few cold start injectors and a seperate pump...   Jun 23 2009, 04:47 PM
yeahmag   Any idea what if anything other than tap water I...   Jun 23 2009, 04:52 PM
BarberDave   :trophy: Neet idea; think about spraying alcoho...   Jun 23 2009, 04:55 PM
yeahmag   I'm just goofing around right now. The idea ha...   Jun 23 2009, 05:01 PM
john rogers   About the only way to cool the engine reliably is ...   Jun 23 2009, 05:14 PM
r_towle   tap water...wont hurt anything...might clog the in...   Jun 23 2009, 05:18 PM
mikez   Go with a bypass and another oil cooler or two. T...   Jun 23 2009, 05:19 PM
SLITS   There was a thread here or maybe the "other s...   Jun 23 2009, 05:30 PM
yeahmag   I have a Setrab and a spin on adapter waiting to g...   Jun 23 2009, 05:31 PM
mikez   If you don't care about looks.....Your local T...   Jun 23 2009, 05:34 PM
Derek Seymour   You could use co2, it's cheap, light, cold, an...   Jun 23 2009, 06:00 PM
porschecb   Just run dry ice through copper tubing it works gr...   Jun 23 2009, 05:47 PM
SLITS   Just run dry ice through copper tubing it works g...   Jun 23 2009, 06:03 PM
Derek Seymour   This is what's being used to cool intercoolers...   Jun 23 2009, 06:14 PM
ConeDodger   A few years back water injection into the intake c...   Jun 23 2009, 05:58 PM
porschecb   Equal spaced small vent holes.   Jun 23 2009, 06:50 PM
jmill   Coil up some copper tubing inside an ice chest fil...   Jun 23 2009, 07:49 PM
jhadler   Apart from the misting being a pretty ineffective ...   Jun 24 2009, 02:27 PM
tat2dphreak   fuck it, put the misters in the cab, like a porch ...   Jun 24 2009, 02:50 PM
- Lo-Fi Version Time is now: 11th July 2025 - 02:10 AM
