FS 914-6 Steering Column Parts SOLD, Delete |
914Sixer |
Jun 25 2009, 04:22 PM
914 Guru Group: Members Posts: 8,885 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I forgot I had these parts, found them in the attic. Parts can be used to make a clone -6 steering column, or buy them for spares
Steering shaft, upper and lower bearing $100 Used 69& 71 911 TS Switch $50 Used 911 tube shaft $10 Tube shaft can be welded to stock 4 mounting plate for clone use TS Switch can be modified by Jeff Bowlsby into a NLA -6 switch Attached image(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 04:28 AM |
