On a 5 lug conversion, are the rear studs longer than the fronts? |
turnaround89 |
Jun 29 2009, 12:04 AM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Is the most common length for a wheel stud for fuchs rims 45mm? Are the rear lugs supposed to be longer at 52mm, or are they also 45mm?
Also, why are wheel studs 7 dollars a stud? Have to buy 20 studs, 140 for studs is a little crazy |
SirAndy |
Jun 29 2009, 12:31 AM
Resident German Group: Admin Posts: 41,643 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Is the most common length for a wheel stud for fuchs rims 45mm? Are the rear lugs supposed to be longer at 52mm, or are they also 45mm? Also, why are wheel studs 7 dollars a stud? Have to buy 20 studs, 140 for studs is a little crazy They are any length you want them, or better yet, you need them. I tried several different lengths and finally just got tired of running out of thread so i got a set of 100mm wheel studs all around. Now i can run any spacer combination i need (different offset for street and track wheels) and not have to worry about thread engagement. The 100mm studs are ~$10 a piece ... (IMG:style_emoticons/default/shades.gif) Andy |
Lo-Fi Version | Time is now: 18th May 2024 - 03:38 PM |
