On a 5 lug conversion, are the rear studs longer than the fronts? |
turnaround89 |
Jun 29 2009, 12:04 AM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Is the most common length for a wheel stud for fuchs rims 45mm? Are the rear lugs supposed to be longer at 52mm, or are they also 45mm?
Also, why are wheel studs 7 dollars a stud? Have to buy 20 studs, 140 for studs is a little crazy |
underthetire |
Jun 29 2009, 10:09 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Longer studs don't work well with some spacers. If you have a thicker spacer 1" or more, the spacers come with studs pressed in for the wheel. The studs you purchase in this case should not stick out more than one inch past the rotor flange.
SirAndy |
Jun 29 2009, 06:29 PM
Resident German Group: Admin Posts: 41,658 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Longer studs don't work well with some spacers. (IMG:style_emoticons/default/confused24.gif) That's how the factory did it. In fact, most consider the bolt on spacers you describe as unsafe ... (IMG:style_emoticons/default/shades.gif) Andy |
Lo-Fi Version | Time is now: 25th May 2024 - 01:59 PM |
