Ball joints, Can i put late style ball joints in an early control arm |
turnaround89 |
Jul 5 2009, 11:58 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I need to get a new drivers side spindle and had someone pm me about purchasing spindles from a 74, i know the ball joints are different. what i was wondering was, can i put late type ball joints in my 1972 control arms to accept the spindle from a 74? Will my brake calipers still fit correctly as well on the 74?
Cap'n Krusty |
Jul 6 2009, 12:32 AM
Yes, the ball joints can be installed in the early control arms. No, the calipers (and rotors) won't fit (unless you allready have the weird inbetween struts)
The Cap'n |
tat2dphreak |
Jul 6 2009, 07:43 AM
check your vin, too... late 72 has the 73+ front end, in which case, the 74 calipers and rotors do work... 4722919032 is the cut-off, if it's higher than that... you are golden.
mine even had the brackets for the stock front sway bar. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:50 AM |
