| pcar916 |
Jul 6 2009, 08:21 AM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
I'm adding a cooler and pump to my transmission. These two pumps are similar in specification and both companies have been around a long time.
Tilton: http://www.summitracing.com/parts/TIL-40-524/ Mocal: http://www.racerpartswholesale.com/product...ial_Cooler_Pump I know several of you run Jabsco Water Puppy pumps, but I see no advantage to it over the Mocal or Tilton. Anyone out there with experience as to whether one is more reliable than the other? |
pcar916 Mocal vs Tilton oils cooler pumps Jul 6 2009, 08:21 AM
ArtechnikA
I'm adding a cooler and pump to my transmissi... Jul 6 2009, 09:00 AM
pcar916
I haven't tested the transaxle fluid temps in... Jul 6 2009, 09:11 AM
ArtechnikA
265°F degree transmission fluid scares me no mat... Jul 6 2009, 09:17 AM
pcar916
265°F degree transmission fluid scares me no ma... Jul 6 2009, 10:07 AM
puff adder I've read about cooling systems with spray bar... Jul 6 2009, 06:47 PM
ArtechnikA
I've read about cooling systems with spray ba... Jul 6 2009, 07:25 PM
puff adder Thanks for the info.
I guess I'm more intere... Jul 6 2009, 08:39 PM
pcar916 You could do it if you ignored squirters on the ge... Jul 6 2009, 09:21 PM
stownsen914
If you decide to install squirters, don't mak... Jul 7 2009, 08:00 AM
pcar916
If you decide to install squirters, don't ma... Jul 7 2009, 09:09 AM
stownsen914
[quote name='stownsen914' post='1189240' date='Ju... Jul 8 2009, 05:30 AM
john rogers I would recommend calling several shops that RACE ... Jul 7 2009, 12:15 AM
Downunderman If you are running a 6 a sportomatic pump off the ... Jul 7 2009, 12:48 AM
pcar916 Downunderman...
- I have a power take-off on the ... Jul 7 2009, 09:38 AM
john rogers If you hook up the plumbing system you might be su... Jul 7 2009, 10:26 AM
pcar916
If you hook up the plumbing system you might be s... Jul 7 2009, 11:03 AM
john rogers I guess I am getting old as I forgot to mention to... Jul 7 2009, 11:34 AM
pcar916
I guess I am getting old as I forgot to mention t... Jul 7 2009, 03:44 PM
jt914-6 I've got a brass 1/2" female one way valv... Jul 7 2009, 05:14 PM
pcar916
I've got a brass 1/2" female one way val... Jul 7 2009, 05:48 PM
Downunderman I have been using the sporto pump for a couple of ... Jul 7 2009, 05:28 PM
pcar916
I have been using the sporto pump for a couple of... Jul 7 2009, 06:21 PM
pcar916 Spraying on the individual gears is good, just not... Jul 8 2009, 07:38 AM
stownsen914
Spraying on the individual gears is good, just no... Jul 9 2009, 05:12 AM
Downunderman Ron,
You should be able to find a sporto pump lay... Jul 8 2009, 09:03 PM
john rogers Remember, if the lube and cooler pump is engine dr... Jul 8 2009, 11:14 PM
puff adder Where is the cooler itself usually mounted?
Did ... Jul 9 2009, 09:44 AM
ArtechnikA
Cooli... Jul 9 2009, 11:07 AM
pcar916 Excellent discussion and why I like this forum. I... Jul 9 2009, 11:12 AM
Downunderman Here are some photos for posterity. Before it had... Jul 10 2009, 03:21 PM
pcar916 You realize your car is far too clean right? Nice ... Jul 11 2009, 08:02 AM
maf914 I remember reading in 24:16: Le Mans 24 Hours that... Jul 15 2009, 03:17 PM
john rogers Here are a couple of picts of the setup I had and ... Jul 15 2009, 03:31 PM
pcar916 Simple... fan underneath or scoop only? Jul 15 2009, 10:21 PM
john rogers An axial boat ventilation fan was added after thes... Jul 16 2009, 12:55 AM
pcar916
An axial boat ventilation fan was added after the... Jul 16 2009, 07:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:31 PM |
