| Daiberl |
Jul 8 2009, 09:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 575 Joined: 22-June 09 From: Seattle, WA Member No.: 10,497 Region Association: Pacific Northwest |
Hello,
wanted to drop my engine but 3 bolts for the CV Joints are locked, I didn't get them out (car was parked for 20 years). Any tips/ideas for dropping the engine with CV Joints, would it help if I drop the engine a few inches and then try it agian with more space under the car? - Juergen |
| r_towle |
Jul 8 2009, 09:47 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
sreees....not a word.
If the CV joint bolts are stuck, use a very good large set of vice grips to get them moving. Due to the geometry, you need to remove them to allow the motor to drop. If its a parts car, removing the outer trailing arms at the same time is an option. RIch |
| Daiberl |
Jul 8 2009, 09:49 PM
sreees....not a word. If the CV joint bolts are stuck, use a very good large set of vice grips to get them moving. Due to the geometry, you need to remove them to allow the motor to drop. If its a parts car, removing the outer trailing arms at the same time is an option. RIch Changed it to bolts (IMG:style_emoticons/default/smile.gif) It's not a parts car, I plan to restore since it's a LE. |
| r_towle |
Jul 8 2009, 09:58 PM
good , possibly NEW vice grips will do it.
They are hardened bolts so you need sharp toothed vice grips...and the big ones so you can get a really tight grip...so tight you can barely close the vice grips....use two hands to close them... They do move...it just takes the right tools. Rich |
| john rogers |
Jul 8 2009, 11:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
If you can get the correct socket (12 pt) into the bolt you can use an impact wrench and a long extension to break them loose. I used to loosen and tighten the ones in the race car this way and the shock will loosen them. If you can not break them loose I would drop the trailing arms along with the engine and transmission so you can work on things easier. You might have to cut off the bolt heads and in that case the CV joints will need replacement but if the car has sat for as long as you say then they'll need replacement anyways.
| charliew |
Jul 8 2009, 11:27 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
Why would cv joints wearout from sitting? As a last resort you can use a chisel and hammer to break the bolts loose.
| mightyohm |
Jul 9 2009, 03:12 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,279 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
I second the vice grips, they have never failed me, ever!
| turboturtle |
Jul 9 2009, 07:50 AM
Member ![]() ![]() Group: Members Posts: 56 Joined: 19-February 09 From: Little Rock, Arkansas Member No.: 10,068 Region Association: None |
Correcto, Vice grip WR9 is the tool you need. This is what the pros have used for years.
Works when nothing else will. |
| megfourfun |
Jul 9 2009, 08:13 AM
Newbie ![]() Group: Members Posts: 23 Joined: 20-February 09 From: Louisville, KY Member No.: 10,079 Region Association: None |
| ericread |
Jul 9 2009, 08:48 AM
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
I had a similar situation last year. Rich said a number of times "Use the Vice Grips". Finally, after about a week, I actually followed his advice. What do you know - it actually worked.
Lesson learned - follow Richs' advice Eric Read (IMG:style_emoticons/default/confused24.gif) |
| v82go |
Jul 9 2009, 08:58 AM
Resident Contrarian ![]() ![]() Group: Members Posts: 254 Joined: 9-December 04 From: Lakeland, Fl. Member No.: 3,250 |
If all else fails, use a small pipe wrench (don't ask me how i know)
Bob |
| VaccaRabite |
Jul 9 2009, 09:40 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
And once you get them out, replace them with allen head bolts. Those star point bolts suck ass.
Zach |
| Daiberl |
Jul 9 2009, 09:52 AM
Correcto, Vice grip WR9 is the tool you need. This is what the pros have used for years. Works when nothing else will. What's this WR9 you speak of? Can you link us, I searched real quick with no luck. Where can I get the WR9 Vice grip? A link would be great. |
| turboturtle |
Jul 9 2009, 10:09 AM
Here is the link to the tool in question. The WR stands for the type of claw on the functional end of the wrench. This is also important!
http://irwin.com/irwin/consumer/jhtml/deta...IrwinProd100317 They didn't post all sizes. They show a WR10 probably as good if not better for grip and leverage. I would go for the originals and not the plastic gripped quicker releasing type Home Depot and Lowes have them in their tool section. |
| Katmanken |
Jul 9 2009, 10:18 AM
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
But Zach,
Star point bolts have more engagement area than a hex socket.. More contact area means the force applied to the bolt spreads over more of the material and reduces the likelyhood of the sucker stripping out. That means that the hex socket needs a higher material strength than the star socket Now the wussy materal that they use to make the star male tools is another story... |
| turnaround89 |
Jul 9 2009, 11:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
When i had this probelm, i took a dremel and flattened two sides of the bolt head so i could get an open ended wrench on the end, worked great!!!
| ArtechnikA |
Jul 9 2009, 11:12 AM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
Now the wussy materal that they use to make the star male tools is another story... The cheap stuff is cheap for a reason. Get a good Stahlwille or MetalNerd and they will last a good long time. Late addition due to failing recall earlier today: Hazet is also excellent, and is universally recommended as the best (in a different size) for removing 911 flywheel bolts. |
| Jakeodoule |
Jul 9 2009, 11:31 AM
Member ![]() ![]() Group: Members Posts: 353 Joined: 10-October 08 From: Des Moines Iowa Member No.: 9,630 Region Association: Pacific Northwest |
I agree the star bolts are better.
I got a Snap-on socket and it works great. I would be really concerned about using allen bolts. If it seizes in there like the star bolt, your chances of stripping an allen are greater cause you can get the allen in at a bit of an angle and it WILL strip. The star bolts will really only allow the wrench to go in straight and therefore gripping the bolt better like ArtechNika says. I have had to use a pliers to get the bolt off of the socket after it comes out of the CV. Thats how tight it fits in the bolt. Most Allens fit alittle loose like. Just my 2 cents.... |
| ghuff |
Jul 9 2009, 11:54 AM
This is certainly not what I expected down here. ![]() ![]() ![]() Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
But Zach, Star point bolts have more engagement area than a hex socket.. More contact area means the force applied to the bolt spreads over more of the material and reduces the likelyhood of the sucker stripping out. That means that the hex socket needs a higher material strength than the star socket Now the wussy materal that they use to make the star male tools is another story... This. Use a dremel with a cut off wheel to shave the bolt heads off, and then maybe pop the CV off. I have cut a bunch of these out of VW's that people strip out after using a 6 point. The 12 points are nice when kept clean and etc. I have them on all 4 of our cars here, since they are all VAG products. |
| Katmanken |
Jul 10 2009, 08:31 AM
Don't cut the heads off or you will have a really big problem removing the CV's and axle. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
With the VW and 914 rear drive products, the axles and CV's are designed to pull down after the bolts are removed. Cutting the heads off the bolts will leave the shank of the bolts in the holes and prevent the CV's and axles from moving down.... Then you get the fun job of unscrewing the the shanks of the cut off bolts from the bores in the CV's, and with the heads cut off, you have nothing to grab........ |
Lo-Fi Version | Time is now: 15th April 2026 - 02:13 PM |
