FS stock sized 165 R 15 tires, Set of 4 in great condition |
zambezi |
Jul 9 2009, 11:36 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
For sale a set of tires removed from a project car that wanted wider tires. These are the hard to find 165 R 15 size. They are cooper brand and have only about 1000 miles on them. They have been mounted on the car for about 2 years. The rubber is still fresh and pliable and has no dry rot. The tread is great also.
$200.00 plus shipping. |
Tom_T |
Jul 9 2009, 11:47 PM
What Load & Speed ratings are they? > 165R15 xxH or xxS or xxT ??
What are the last 4 digits after the DOT serial no. on the sidewall in the oval inset or between a couple of "+" "+" or ">" "<" marks? |
zambezi |
Jul 10 2009, 12:05 AM
What Load & Speed ratings are they? > 165R15 xxH or xxS or xxT ?? What are the last 4 digits after the DOT serial no. on the sidewall in the oval inset or between a couple of "+" "+" or ">" "<" marks? I don't see a load or speed rating on the tire. The numbers in the recessed ovals are "C3T3202" which I guess is the serial no. and "E03L". Hope this helps JIM |
Tom_T |
Jul 10 2009, 01:10 AM
What Load & Speed ratings are they? > 165R15 xxH or xxS or xxT ?? What are the last 4 digits after the DOT serial no. on the sidewall in the oval inset or between a couple of "+" "+" or ">" "<" marks? I don't see a load or speed rating on the tire. The numbers in the recessed ovals are "C3T3202" which I guess is the serial no. and "E03L". Hope this helps JIM The "...3202" which I bolded above means the tires were mfgd. in the 32nd week of 2002 - or about mid-July `02 +/-. The Load Rating & Speed Rating are combined in a numeric-letter combination after the tire size on the sidewall, while old 1970's tires had the speed rating letter embedding in the size, for example: OLD:..............................................NEW:...................SPEED RATING: 165VR15.............................................165R15 86V.........V = 149 mph max 165HR15.............................................165R15 86H.........H = 130 mph max 165SR15.............................................165R15 86S.........S = 112 mph max N/A.....................................................165R15 86T.........T = 118 mph max Porsche's 914 OE Spec Tires Speed Ratings: 914/6's had V rated (maybe some H??) 914-2.0L's (4 cyls) had H rated 914 1.7L's & 1.8L's had S rated "86" is the Load Rating & 70-90 range is fine for 914s - (I just picked "86" out of the air for this example) FYI - Many tire dealer & mfgr. websites have online charts for all of the load & speed ratings) |
Lo-Fi Version | Time is now: 19th May 2024 - 10:41 PM |
