916 kit on 915 trans, Who dunnit? |
-JR- |
Jul 15 2009, 11:43 PM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
For those interested in more background on the 915 trans...
I found this WIKI article on a 914 site. -->...HERE...<-- |
Steve |
Jul 16 2009, 08:42 AM
914 Guru Group: Members Posts: 5,613 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Sorry for the hijack, but this is turning into a good trans thread. When I bought my car the previous owner already sunk $8k into the 901 trans. So I am kind of stuck for now. Isn't there a gear flip option to make 5th gear higher so it doesn't rev so high? When I get a chance I will research the other threads. I know the 901 turned into a four speed, eliminating first is still popular with the v8 crowd.
Dr Evil |
Jul 16 2009, 10:16 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Installing a flipped H gear is the most economical way to make a taller 5th and is a popular option. The only other ways, besides the H gear, to get a 901 to have taller gearing than stock is to either have custom gears made, or find the correct year auto tranz and grab the smaller r/p out of it.
-JR- |
Jul 16 2009, 10:20 AM
Sorry for the hijack, but this is turning into a good trans thread. When I bought my car the previous owner already sunk $8k into the 901 trans. So I am kind of stuck for now. Isn't there a gear flip option to make 5th gear higher so it doesn't rev so high? When I get a chance I will research the other threads. I know the 901 turned into a four speed, eliminating first is still popular with the v8 crowd. Doing a quick check on the net, different 5th gears are available for the 901 as well. So you should be able to physically replace it. The only tricky one for the 901 is 2nd gear because it's attached to the main shaft. |
Steve |
Jul 16 2009, 08:27 PM
Installing a flipped H gear is the most economical way to make a taller 5th and is a popular option. The only other ways, besides the H gear, to get a 901 to have taller gearing than stock is to either have custom gears made, or find the correct year auto tranz and grab the smaller r/p out of it. Dumb question Mr. Evil, but where might I find an H gear? What make and model did it come in? How hard is it to change? Enquiring minds want to know. Do I need to pull the trans or would all the guts slide out the rear? Hate it when that happens (IMG:style_emoticons/default/slap.gif) |
Dr Evil |
Jul 16 2009, 08:57 PM
Steve, if you are unfamiliar with how the guts go into the box, you need to read up (IMG:style_emoticons/default/wink.gif) You would need to remove the whole stack and do some serious work to swap the gears. H gears are for sale from me, or other gear vendors like carquip (see link in my sig).
Dr Evil |
Jul 16 2009, 08:58 PM
Sorry for the hijack, but this is turning into a good trans thread. When I bought my car the previous owner already sunk $8k into the 901 trans. So I am kind of stuck for now. Isn't there a gear flip option to make 5th gear higher so it doesn't rev so high? When I get a chance I will research the other threads. I know the 901 turned into a four speed, eliminating first is still popular with the v8 crowd. Doing a quick check on the net, different 5th gears are available for the 901 as well. So you should be able to physically replace it. The only tricky one for the 901 is 2nd gear because it's attached to the main shaft. For stock 5th gears the stock ZD in the 914 901 box is the highest. That is why you are left with flipping a 2nd gear (H). |
Steve |
Jul 17 2009, 08:29 AM
[/quote]
For stock 5th gears the stock ZD in the 914 901 box is the highest. That is why you are left with flipping a 2nd gear (H). [/quote] What does an H gear cost? I didn't see any pricing in the links. |
Dr Evil |
Jul 17 2009, 11:47 AM
You must call for pricing. Prices vary from $300-500.
Lo-Fi Version | Time is now: 9th June 2024 - 03:53 AM |
