914 Type R build |
914 Type R build |
fasthonda |
Jul 26 2009, 10:52 AM
914 Type R Group: Members Posts: 133 Joined: 10-January 04 From: Greenville, SC Member No.: 1,544 Region Association: None |
I would share my project with the world since I enjoy seeing what others have posted. The 914world has been big help in sourcing info, parts, and the car itself.
I thought about building this car for years, and finally decided to act on it. Recomendations and comments are welcome. Thanks, Michael Project Scope Body: 1973 narrow bodied w/ fiberglass bumpers Engine: Honda S2000 F20C (250 ps @ 8200 rpm) Transmission: Stock Front Suspension: 87 911 front end w/ Bilstein Sports, 22 sway bar Rear Suspension 250 lb springs on bilstein sports, poly bushings Wheels: 15x7 with R compound Brakes: 87 911 Carrera F&R This is how it looked when I first got it. Brought this home from Southern Caifornia. The transport company rolled it up in the yard since it had no brakes. Repaired hell hole Reinforced rear suspension console Removed sound deadening from the floor and prepping for POR15 Rear fiberglass bumper fitted I hope to be installing the drivetrain in September, that is if Murphy's law quits getting me. The flywheel from KEP is several thousands too small to fit on the crankshaft so I need to get that resolved first. |
Chris Hamilton |
Sep 3 2009, 09:40 PM
Senior Member Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 |
This is looking cool! What clutch/flywheel are you going to use?
fasthonda |
Sep 4 2009, 09:35 PM
This is looking cool! What clutch/flywheel are you going to use? Chris, The flywheel is from Kennedy Engineering. I will be using the stock 914 clutch and pressure plate. Since the S2K motor is low on torque and the car will be very light the stock setup should be fine. I set the engine under the car today. The S2K motor is very tall. The valve cover will protrude above the engine lid and trunk so these will need to be modified. The Engine still needs to be raised about 8 inches from the position in the picture below. I need to cut the truck section before I can raise it to its final position. I put the cookie cutters on the front today for the first time. I think these wheels look great on the car. |
Lo-Fi Version | Time is now: 20th May 2024 - 02:44 PM |
