914 Type R build |
914 Type R build |
fasthonda |
Jul 26 2009, 10:52 AM
914 Type R Group: Members Posts: 133 Joined: 10-January 04 From: Greenville, SC Member No.: 1,544 Region Association: None |
I would share my project with the world since I enjoy seeing what others have posted. The 914world has been big help in sourcing info, parts, and the car itself.
I thought about building this car for years, and finally decided to act on it. Recomendations and comments are welcome. Thanks, Michael Project Scope Body: 1973 narrow bodied w/ fiberglass bumpers Engine: Honda S2000 F20C (250 ps @ 8200 rpm) Transmission: Stock Front Suspension: 87 911 front end w/ Bilstein Sports, 22 sway bar Rear Suspension 250 lb springs on bilstein sports, poly bushings Wheels: 15x7 with R compound Brakes: 87 911 Carrera F&R This is how it looked when I first got it. Brought this home from Southern Caifornia. The transport company rolled it up in the yard since it had no brakes. Repaired hell hole Reinforced rear suspension console Removed sound deadening from the floor and prepping for POR15 Rear fiberglass bumper fitted I hope to be installing the drivetrain in September, that is if Murphy's law quits getting me. The flywheel from KEP is several thousands too small to fit on the crankshaft so I need to get that resolved first. |
Brett W |
Dec 21 2010, 03:22 PM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
There really ain't a benefit to the hydro trans. I just happened to buy the swap with a hydro tranny. They cable trans can handle similar pressure plates. No need to run massive pressure plates.
My 90 Hatch was a full z6 swapped with the turbo kit I built. made 240 at the wheels. I was going to do a custom ZC/Si gearbox swap but decided to go ahead and step up to the CG transmission from the first gen integra. That is what I am going to use in the race car. Gonna stick with the Built Z6. Adding a bigger turbo and header, some all out custom suspension stuff blah,blah, blah. Even have a new roof panel to weld on to get rid of the sun roof. As for your car make sure you convert it to OBD 1. There really isn't a good way to control your engine with all the bolt on garbage. However if you want an Apexi AFC let me know the CRX has one that will be sold as soon as I yank it out. You need more compression and more cam to really make that engine work right. Use the ZC or PM7 pistons to get the compression up, then drop in a bigger cam. The ZEX cam is reasonably priced. Add the ZC/Si gear box and you will have a car that is a riot to drive. Of course it will probably get stolen in 20 minutes out in CA. I have parts if you need anything, let me know. |
Lo-Fi Version | Time is now: 20th May 2024 - 12:47 PM |
