914 Type R build |
914 Type R build |
fasthonda |
Jul 26 2009, 10:52 AM
914 Type R Group: Members Posts: 133 Joined: 10-January 04 From: Greenville, SC Member No.: 1,544 Region Association: None |
I would share my project with the world since I enjoy seeing what others have posted. The 914world has been big help in sourcing info, parts, and the car itself.
I thought about building this car for years, and finally decided to act on it. Recomendations and comments are welcome. Thanks, Michael Project Scope Body: 1973 narrow bodied w/ fiberglass bumpers Engine: Honda S2000 F20C (250 ps @ 8200 rpm) Transmission: Stock Front Suspension: 87 911 front end w/ Bilstein Sports, 22 sway bar Rear Suspension 250 lb springs on bilstein sports, poly bushings Wheels: 15x7 with R compound Brakes: 87 911 Carrera F&R This is how it looked when I first got it. Brought this home from Southern Caifornia. The transport company rolled it up in the yard since it had no brakes. Repaired hell hole Reinforced rear suspension console Removed sound deadening from the floor and prepping for POR15 Rear fiberglass bumper fitted I hope to be installing the drivetrain in September, that is if Murphy's law quits getting me. The flywheel from KEP is several thousands too small to fit on the crankshaft so I need to get that resolved first. |
fasthonda |
Dec 22 2010, 05:25 PM
As promised here are a few detailed pics of the cars current state.
The radiator will be completely shrouded once finished. |
stewteral |
Dec 27 2010, 10:58 PM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Hey Fasthonda,
I love your converion and compliments on the good work! It's a great conversion idea and with such a stout engine, I'm wondering about supercharging! That you really make it fly! My car is a V8 conversion and I also had to raise the engine cover....it isn't even noticeable! When I noticed your radiator install, I believe I saw that your plan to vent out the bottom of the car. I wanted to pass on that I tried this for a couple years with my car and even with an airdam 2" from the ground and 2 big fans, the car still ran HOT on-track. Most of V8 conversions exhaust out the fenderwells and while it seems to work, the BEST way is our the top of the hood. Check out what bynbad914 has done in the attached photo. My solution is similar ala racing sports cars. Since the Honda won't be producing the heat of my 383 Chevy, a modest opening should to the job. Best of luck, keep the photos coming!! Terry |
fasthonda |
Dec 28 2010, 04:50 PM
When I noticed your radiator install, I believe I saw that your plan to vent out the bottom of the car. I wanted to pass on that I tried this for a couple years with my car and even with an airdam 2" from the ground and 2 big fans, the car still ran HOT on-track. Most of V8 conversions exhaust out the fenderwells and while it seems to work, the BEST way is our the top of the hood. Check out what bynbad914 has done in the attached photo. My solution is similar ala racing sports cars. Since the Honda won't be producing the heat of my 383 Chevy, a modest opening should to the job. Thanks for the advice Terry. From reading the forums I was aware of this, but not until after I finished my original setup. I gonna give this a try and monitor the water temp closely. It won't take too much to angle the radiator forward and vent out the hood if neccesary. Plently of good deals on Ebay for Louvers. Michael |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:30 PM |
