914 Type R build |
914 Type R build |
fasthonda |
Jul 26 2009, 10:52 AM
914 Type R Group: Members Posts: 133 Joined: 10-January 04 From: Greenville, SC Member No.: 1,544 Region Association: None |
I would share my project with the world since I enjoy seeing what others have posted. The 914world has been big help in sourcing info, parts, and the car itself.
I thought about building this car for years, and finally decided to act on it. Recomendations and comments are welcome. Thanks, Michael Project Scope Body: 1973 narrow bodied w/ fiberglass bumpers Engine: Honda S2000 F20C (250 ps @ 8200 rpm) Transmission: Stock Front Suspension: 87 911 front end w/ Bilstein Sports, 22 sway bar Rear Suspension 250 lb springs on bilstein sports, poly bushings Wheels: 15x7 with R compound Brakes: 87 911 Carrera F&R This is how it looked when I first got it. Brought this home from Southern Caifornia. The transport company rolled it up in the yard since it had no brakes. Repaired hell hole Reinforced rear suspension console Removed sound deadening from the floor and prepping for POR15 Rear fiberglass bumper fitted I hope to be installing the drivetrain in September, that is if Murphy's law quits getting me. The flywheel from KEP is several thousands too small to fit on the crankshaft so I need to get that resolved first. |
bam914 |
Feb 14 2011, 09:05 PM
Member Group: Members Posts: 334 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
I have a 914 trans with a 4.8 final drive if the stock one is too tall.
fasthonda |
Feb 24 2011, 07:33 PM
I have a 914 trans with a 4.8 final drive if the stock one is too tall. Blake, I'm Interested. How much? With a power band from 6500 to 8500 rpm I will definitely need to shorten the gear ratios. I calculated I need E,K,Q gear sets for 2,3,and 4. These are probably be hard to find. Also needing a set of 15x7 fuchs wheels. Michael |
bam914 |
Feb 25 2011, 11:11 AM
I have a 914 trans with a 4.8 final drive if the stock one is too tall. Blake, I'm Interested. How much? With a power band from 6500 to 8500 rpm I will definitely need to shorten the gear ratios. I calculated I need E,K,Q gear sets for 2,3,and 4. These are probably be hard to find. Also needing a set of 15x7 fuchs wheels. Michael This will not change the RPM drop between gears. It will raise the RPM need to attain the same MPH. I will PM you a price on the trans. Blake |
Lo-Fi Version | Time is now: 20th May 2024 - 02:40 PM |
