914 Type R build |
914 Type R build |
fasthonda |
Jul 26 2009, 10:52 AM
914 Type R Group: Members Posts: 133 Joined: 10-January 04 From: Greenville, SC Member No.: 1,544 Region Association: None |
I would share my project with the world since I enjoy seeing what others have posted. The 914world has been big help in sourcing info, parts, and the car itself.
I thought about building this car for years, and finally decided to act on it. Recomendations and comments are welcome. Thanks, Michael Project Scope Body: 1973 narrow bodied w/ fiberglass bumpers Engine: Honda S2000 F20C (250 ps @ 8200 rpm) Transmission: Stock Front Suspension: 87 911 front end w/ Bilstein Sports, 22 sway bar Rear Suspension 250 lb springs on bilstein sports, poly bushings Wheels: 15x7 with R compound Brakes: 87 911 Carrera F&R This is how it looked when I first got it. Brought this home from Southern Caifornia. The transport company rolled it up in the yard since it had no brakes. Repaired hell hole Reinforced rear suspension console Removed sound deadening from the floor and prepping for POR15 Rear fiberglass bumper fitted I hope to be installing the drivetrain in September, that is if Murphy's law quits getting me. The flywheel from KEP is several thousands too small to fit on the crankshaft so I need to get that resolved first. |
westtexass2k |
Sep 21 2012, 03:53 PM
Newbie Group: Members Posts: 40 Joined: 31-December 11 From: San Angelo Tx Member No.: 13,954 Region Association: None |
I am glad I stumbled across this thread. I have been gathering parts for the last year for this very build. I have the engine and the car and Im saving up for the adapters from KEP. I think the f20c is a great choice for a teener. It should run circles around most cars. The S2000 is 2800lbs and your car is probably near 2000 lbs. It will walk all over a stock S2000.
I have done many F20c conversions and Im very familiar with the wirirng. Your correct on the VSS needed. It needs to go back to the Ecu connector A pin 9 if my memory is correct. i have it in a wiring diagram at the house. Your vtec will work but it will go into limp mode once you get up to 110mph or so. You can disconnect power to the ecu clear the code and it will run great again until limp mode hits again. I can tell you how to bypass the antitheft if you want to get rid of that. my number is on my website if you need help sorting the wiring out. I can send you a wirirng diagram too. www.worldclassmotorsports.com Great build and look forwad to the finish results and impressions. |
Lo-Fi Version | Time is now: 20th May 2024 - 02:46 PM |
