> Trying to decide whether or not to rebuild, ?
buhs914
post Aug 8 2009, 09:08 PM
Not So Newbie
Well i have my engine out and mostly stripped so i can clean the gunk off from the oil leak.. while i have it out should i rebuild it? i have no idea when it had it done last.. i don't believe that in needs to be done but who knows..
r_towle
post Aug 8 2009, 09:27 PM
Custom Member
Clean it, fix the leak..put it back together, put it back in, Drive it like you stole it...
then in late november pull the motor and rebuild it.
Rich
type47
post Aug 8 2009, 09:30 PM
Viermeister
or buy a motor to rebuild as you drive it like you stole it.... (IMG:style_emoticons/default/biggrin.gif)
then when you're ready, swap it out in a weekend...
if it runs, I don't see the need to rebuild unless compression or leakdown tests show definite faults..
3d914
post Aug 9 2009, 09:46 AM
I agree.
914's tend to spend too much time in the garage once you start the process. So get out there now while you can!
Enjoy!
- Lo-Fi Version Time is now: 8th November 2025 - 06:31 PM
