914 newbie. Just bought my first 72 1.7l fi, bone stock... |
blazerchad |
Aug 18 2009, 01:01 PM
Newbie Group: Members Posts: 35 Joined: 16-August 09 From: portland oregon Member No.: 10,684 Region Association: None |
Wanted one of these for years... found it after being in storage for 12 years.. never driven, just started and maintained.. crazy low original miles on it, no crazy electrical slices and dices, wiring looks great, in fact, over all the crazy cars I have bought, this 914 is the cleanest, lowest rust, lowest damage/ modifications of any rig I have ever bought..
started it, drove it! offered money, they took it... I went back to drive it to a buddies with a garage... no start... here I sit, at my buddies garage... turn the key... flashing from the hazard relay. no lights exterior, just flashing in the heads up display. no power to the fuel pump magically. run a hot lead to it, it fires up... turn the key and (below the infernal clicking of the hazard relay ) I hear no fuel pump for the required second or so... nothing. spray a little thrust into the intake, starts easy. changed the fuel filter, of course had to replace the hose to the fuel pump too, thats when I tested it, having flashes of lighting on fire remembering I have a hot lead form the battery dangling.. (I had just tested the pump) So here i sit in portland oregon, beating my head against a wall to the beat of my hazard flasher... click click click..... (IMG:http://photos-c.ak.fbcdn.net/photos-ak-sf2p/v5202/72/103/683318520/n683318520_2285842_6751939.jpg) |
Cevan |
Aug 18 2009, 01:18 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
First, (IMG:style_emoticons/default/welcome.png)
Second, have you checked the fuel pump relay. It's the third round relay (going front to back) on the relay board in the engine bay. Assuming your headlights go up and down, you could swap out the fuel pump relay for a known working headlight relay. There is also a 25amp fuse on the relay board that could be blown (and was the cause of my no start problem). turn the key and (below the infernal clicking of the hazard relay ) I hear no fuel pump for the required second or so... nothing. |
Shade Tree |
Aug 18 2009, 01:31 PM
Member Group: Members Posts: 260 Joined: 18-December 08 From: Springfield, Oregon Member No.: 9,860 Region Association: Pacific Northwest |
I really like that color.... Don't worry, these guys will help you get it going again.
blazerchad |
Aug 18 2009, 01:46 PM
making progress with a little searching on this forum... The flashing in the headset.. top middle of left heads up, warning light... handbrake or master cylinder.
Im assuming hand brake, it was frozen up when i got the rig, tore out the seat and free'ed the HB up, must have messed with the switch at that point. checked the fuse for the pump relay, power in and power out, buying a new fuel relay to switch out. also, my center relay in engine compartment has a red relay, all pretty and in the middle, this i assume is power to the board.. that might be bad... sound like a symptom? (IMG:http://photos-b.ak.fbcdn.net/photos-ak-sf2p/v5202/72/103/683318520/n683318520_2285777_5292275.jpg) |
tod914 |
Aug 18 2009, 01:48 PM
If the fuze is blown, and it continues to blow, it's probally the auxillery air regulator shorting it out. In that case, disconnect the AAR and plug the end where it goes into the air cleaner, and also the on the aircleaner.
You can find spare relays in your headlight motors (remove the plastic shield). Keep note of the orientation of the relay. They are numbered and need to go in a certian way. Its relay 75. http://www.pelicanparts.com/914/parts/elec...ric_71relay.jpg Nice car btw and good luck with it. |
zymurgist |
Aug 18 2009, 02:04 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
The flashing light can be caused by the master cylinder of the switch on the parking brake lever... I've never been able to get that switch to line up correctly on Babydoll. You west coast guys are so lucky... "low rust" indeed! Does it have the original fuel injection? Regardless of what the fuel system is, you might want to think about replacing the tunnel fuel lines before driving it on a regular basis. We're talking major fire prevention here (not trying to scare you, but it has happened). |
montoya 73 2.0 |
Aug 18 2009, 02:06 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
blazerchad |
Aug 18 2009, 02:12 PM
no idea... its a silver and black, with a respray over the silver... with silver... (IMG:style_emoticons/default/smile.gif) |
zymurgist |
Aug 18 2009, 02:13 PM
I really like that color.... (IMG:style_emoticons/default/agree.gif) Babydoll was originally silver (now white). I found that out when I pulled the gas tank and the body under the tank was silver. |
blazerchad |
Aug 18 2009, 03:12 PM
gonna go work on it now... hope i make headway.. I really hope my fuel pump just isnt getting power from the relay... downloaded some wiring diagrams.. try to test tham a bit..
ME733 |
Aug 21 2009, 10:30 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
(IMG:style_emoticons/default/welcome.png) The flashing light can be caused by the master cylinder of the switch on the parking brake lever... I've never been able to get that switch to line up correctly on Babydoll. You west coast guys are so lucky... "low rust" indeed! Does it have the original fuel injection? Regardless of what the fuel system is, you might want to think about replacing the tunnel fuel lines before driving it on a regular basis. We're talking major fire prevention here (not trying to scare you, but it has happened). PLEASE do CONSIDER replacing ALL the fuel system lines. on any car thats been sittiong up, reguardless of the low mileage, the rubber bits, fuel lines , will simply dry out, and crack and spew fuel.= fire hazzard.,seems like you are a car guy, but ....the 914,s seem to be prone to fuel leakage problems...welcome to 914 world. |
zx-niner |
Aug 21 2009, 05:53 PM
Member Group: Members Posts: 294 Joined: 13-June 05 From: Las Vegas, NV Member No.: 4,269 Region Association: Central California |
My very first 914 in 1978 was a bone stock 1972 1.7l. Absolutely the best car I ever owned, including the current 914. Well, bone stock except for the wheels. These were chic in the 70's. And except for the spoiler and exhaust. Even then we couldn't leave them stock. But after an engine rebuild in '79 it was the finest running 914 anywhere. Plenty of power for the light car, absolute reliability, well over 30 mpg. When I look at other photos I'm amazed at how well everything fit when these cars were new(er).
It was also my first 914 to go the the wrecking yard after I tried to pull out blind into traffic. Sigh. I probably would still have it, although in the 80's would have put on a Chalon kit with a V6, and painted it red. Maybe it was better this way. |
roadster fan |
Aug 21 2009, 08:33 PM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
Electrical problem in a 914, and no one on this board has suggested checking the................
GROUNDS. I would check all of them. the ones by the relay board, the ones on the engine in the middle below the intake plenum (you can get to them from passenger side with the aircleaner off), and the ones under the dash, and by the brake fluid reservoir. Hope this helps a little, make sure to report back. Jim |
plas76targa |
Aug 22 2009, 06:21 AM
Senior Member Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region |
Jim - you beat me to that ... grounds. Check them all. I sprayed electric cleaner on the one near the fuse panel / drivers door. I'll add change the transmission fluid (at LEAST check the level). Fresh gear lube and engine oil wouldn't hurt.
Welcome to the board! |
IronHillRestorations |
Aug 22 2009, 09:45 AM
Change the brake fluid. That's a 2 year service interval, and I'd bet yours hasn't been replaced in a long time.
blazerchad |
Aug 22 2009, 06:52 PM
changing out the alternator now...
had to replace the distibutor... an armature broke off opposite the points, a ball bearing, spring/cup set up to keep the advance plate from moving up and down. . it was broke and sitting in the bottom of the distributor... i replaced the distributor with another one via a local garage, they struggled finding a replacement for the original. guess i will have to rebuild the stock distributor... my tach is gone now... wont work... gonna go run and put the new alt in... hey, whats the little box on the ass end of the distributor, one wire, hooked to the post labeled b+. hot to opposite side...(also labeled b+) chad |
Pat Garvey |
Aug 22 2009, 07:19 PM
Hmm, how old is the gas? Shined a flashlight (not your BIC) into the tank? Pat |
blazerchad |
Aug 22 2009, 07:34 PM
gas is good, all drained and fresh gas.. i have it running...
drove it for a coupla hours from portland to eugene.. distributor assed out, now im working on charging system... should i go to an internally regulated alt? or keep the voltage regulator? im thinking of taking back this rebuilt, go to an alt shop and have my old one rebuilt.. hmmm |
blazerchad |
Aug 22 2009, 07:36 PM
oh, and the flashing heads up is gone.. it was the brake sensor im guessing.. electrics are a little crazy...
no signals, no fog lights, no blower motor for heat, no heat electrics, hazards work, no flashers, headlights work, thats about it... step on the brake and one taillight goes out... crazy... |
blazerchad |
Aug 23 2009, 11:27 AM
now the tach is working...
The vw shop i took it to (replaced the distributor checked fuel system and timed the car) managed to dislodge the tach wire going to the coil. checked the trans ground strap, bright, shiny, new and tight... going to go through all the bulbs, replace and re-check.. any word out there on one wire alternator set up? |
Lo-Fi Version | Time is now: 15th May 2024 - 03:42 PM |
