Tach getting hung up... |
Ferg |
Aug 23 2009, 07:18 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
OK this is a new one for me.
Tach works fine going through the gears, (maybe possible slowing in the the 2900-3300 range. Today on the highway (first for me and this car) the tach was getting hung up on certain rpms, say 3150, then get on the gas, I could go about 10 mph faster before it moved again, same with decel, if I held a constant speed, then started coasting, it would not move right away. Seems to only happen in that range 2900-3300 ish. all else seems normal. Any ideas? Car has a fresh tune, stock djet 74 2.0. Ferg |
Spoke |
Aug 23 2009, 09:24 PM
Does the tach needle stick or does it seem like the engine isn't running good? Almost sounds like a mechanical problem with the tach.
Ferg |
Aug 23 2009, 10:07 PM
Does the tach needle stick or does it seem like the engine isn't running good? Almost sounds like a mechanical problem with the tach. Engine is running excellent. So, yes, to me it seems like a mechanical problem with the tach as well. I hate to swap it out, but may have to. It's a super nice tach, (silver dot no fading on the red ect) Ferg |
Lo-Fi Version | Time is now: 12th May 2024 - 12:40 AM |
