window adjustments |
kenshapiro2002 |
Aug 23 2009, 08:08 PM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Is there any way to bring the top of the side windows inward more...closer to the seals?
john rogers |
Aug 23 2009, 08:53 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Yes, there is an adjuster at the bottom of the door and if you follow a line that would run from the front of the side window down and then under the sheetmetal you will see the lock nut and adjuster screw. Sometimes they get rusted up due to water in the bottom of the door so you might have to soak it some. I forget which way you turn the adjuster screw to move the top inward but you can experiment.
kenshapiro2002 |
Aug 23 2009, 08:58 PM
Thanks.
Yes, there is an adjuster at the bottom of the door and if you follow a line that would run from the front of the side window down and then under the sheetmetal you will see the lock nut and adjuster screw. Sometimes they get rusted up due to water in the bottom of the door so you might have to soak it some. I forget which way you turn the adjuster screw to move the top inward but you can experiment. |
Lo-Fi Version | Time is now: 13th May 2024 - 12:09 AM |
