| gopack |
Aug 27 2009, 12:57 PM
CHEESEHEAD in CA, MARK ![]() ![]() ![]() Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
Elephant racing makes the tie rod end solution. Like everything they sell , it is high quality, and pricy: $335
| SirAndy |
Aug 27 2009, 01:01 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,510 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Elephant racing makes the tie rod end solution. We've been using a similar setup on the green 911 race car for years without any trouble. Those work great and are easy to adjust. (IMG:style_emoticons/default/shades.gif) Andy |
| turboman808 |
Aug 27 2009, 01:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
I really thought my car had this and just needed some adjustment. Guess I got to buy it sooner rather then later.
| jim_hoyland |
Aug 27 2009, 02:59 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,130 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Does raising the spindles or using the ER bump steer kit end up doing the same thing ?
| SirAndy |
Aug 27 2009, 03:02 PM
Does raising the spindles or using the ER bump steer kit end up doing the same thing ? No. Raising the spindles allows you to lower the car past what is possible otherwise. (IMG:style_emoticons/default/shades.gif) Andy |
| turboman808 |
Aug 27 2009, 03:13 PM
Does raising the spindles or using the ER bump steer kit end up doing the same thing ? No one has given a definitive answer and even elephant racing doesn't give one. I would really assume the goal is to get the tie rod close to parallel to the lower a arm. In the pictures shown you can see it makes a trianlge. A arm is pointing down and tierod is pointing up. Correct me if I am wrong but that seems to me it would cause the tires to toe out over a bump. All the bump steer kits bring the tie rod down making this trianlge less severe. I think moving the spindle up makes the problem worse. Again no experience with this just looking at the pictures. (IMG:style_emoticons/default/smile.gif) |
| J P Stein |
Aug 27 2009, 03:17 PM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I hope all my work can help you understand what is happening with the 914 suspension: I have to keep reminding myselft that the car was DESIGNED around 100 HP and 165 radials....ONLY. So the best tip I can give is to run the car at STOCK suspension ride-height and setting......and if you PLAN to be "Up on the Wheel" maybe 1/6- 1/8" TOE-OUT in the rear. Best of luck, Terry An old fat guy thinks your understanding of the 914s suspensions is pretty good. Your conclusions are....well, *your* conclusions & thankfully, not mine. Lowring the car is very worthwhile.....as long as it is done right & with consideration given to bump. |
| J P Stein |
Aug 27 2009, 06:33 PM
Angles..we gots em and it works. I'm at 4-3/4 inches at the doughnuts. I was lower but had wheel to A arm interference at a lot of steering lock & suspension compression..so back up we went.....who'da thunk it.....
Jim: With raised spindles it takes either bending the steering arm.....which buggers up the Ackerman or tie rod extensions....these are by ERP. It can run into money to get both. Attached thumbnail(s) |
| SirAndy |
Aug 27 2009, 06:40 PM
Angles..we gots em and it works. Yeah, but your overall suspension travel is what, a micrometer? (IMG:style_emoticons/default/rolleyes.gif) On a mostly stock suspension, with lots of travel, the more unparallel the arm is in regards to the tie rod the worser the bumpness steering gets ... (IMG:style_emoticons/default/stirthepot.gif) Andy |
| J P Stein |
Aug 27 2009, 06:55 PM
I have 2 1/2 inches of front shock travel & use it all. 21 mm T bars ain't all that stiff.
What you want to avoid is going over center with the tie rod....and the A arm for that matter. |
| cwpeden |
Aug 27 2009, 07:10 PM
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
You need to account for the pivot points of the tie rod are constantly changing in relation to the a-arm, which is static.
Oh, and what about camber and caster..... (IMG:style_emoticons/default/stirthepot.gif) |
| J P Stein |
Aug 27 2009, 07:20 PM
You need to account for the pivot points of the tie rod are constantly changing in relation to the a-arm, which is static. Oh, and what about camber and caster..... (IMG:style_emoticons/default/stirthepot.gif) Ya gotta account for a lot of things. You won't find them all till you try something.....and, of course, it is possible to make a hash of it.....then go to plan B. (IMG:style_emoticons/default/biggrin.gif) |
| ArtechnikA |
Aug 27 2009, 07:54 PM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
| jaxdream |
Aug 27 2009, 08:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
It binds things in other places...namely the upper u-joints. you mean the steering shaft U-joints? They're splined, and the shaft can be adjusted for length. put in the spacers, loosen the clamp nuts, let the joint shafts retract into the outer shaft, retighten. What type of steering shafts you using ?? (IMG:style_emoticons/default/confused24.gif) Mine do have the splined ends as most 914's I 've seen , but some also have a half moon cutout on them for the bolt that binds them to slide through and locate the u-joint on the shaft , adjustment , all I can do to mine is install a thinner hockey puck on the rack to allow for raising the rack to run spacers. The rack shaft to inside is covered up by a plastic cover and it would have to be trimed back as it butts up against the upper shaft bearing that's under the clamp behind the fuel tank. There maybe some adjustment there , but not much other than a thinner hockey puck. Jaxdream |
| dw914er |
Aug 27 2009, 08:58 PM
Planning Cities ![]() ![]() ![]() ![]() Group: Members Posts: 2,365 Joined: 1-March 08 From: Yucaipa, CA Member No.: 8,763 Region Association: Southern California |
This is what is on clubrsx from my searches while modifying my suspension on my rsx
QUOTE First, I'll talk about what bumpsteer is NOT. It is NOT when the steering wheel moves when you hit a bump. That often is caused by high spring rates or high tie pressures. Imagine riding your bike with no tires. As soon as it hits a bump, you are going to feel it and it is going to push your wheel in a certain direction. When spring rates or tire pressures are really high, the suspension is really stiff and the car responds quickly and not necessarily in the right way. Remember, high spring rates don't = better handling. Race cars use high spring rates because they allow quick responding, but they also are racing on smooth surfaces and not on crappy city roads. The short answer is that bumpsteer is when your wheels turn without input from the driver. It is affected by toe. On our suspension, when it compresses, toe goes in and the opposite happens with rebound. To control bumpsteer, one would want to keep toe settings pretty static throughout compression and rebound. From what I understand, camber can and will affect toe, so the common results of bumpsteer from after lowering a car is bad alignment, creating what the quote said. Is this true, and could be why Jim hasn't noticed massive bumpsteer, because the alignment probably isn't that far out of wack? I don't really know, but alot of their stickies makes sense for the rsx applications, so I assumed this one was good also. |
| jim_hoyland |
Aug 27 2009, 09:48 PM
This is what is on clubrsx from my searches while modifying my suspension on my rsx QUOTE First, I'll talk about what bumpsteer is NOT. It is NOT when the steering wheel moves when you hit a bump. That often is caused by high spring rates or high tie pressures. Imagine riding your bike with no tires. As soon as it hits a bump, you are going to feel it and it is going to push your wheel in a certain direction. When spring rates or tire pressures are really high, the suspension is really stiff and the car responds quickly and not necessarily in the right way. Remember, high spring rates don't = better handling. Race cars use high spring rates because they allow quick responding, but they also are racing on smooth surfaces and not on crappy city roads. The short answer is that bumpsteer is when your wheels turn without input from the driver. It is affected by toe. On our suspension, when it compresses, toe goes in and the opposite happens with rebound. To control bumpsteer, one would want to keep toe settings pretty static throughout compression and rebound. From what I understand, camber can and will affect toe, so the common results of bumpsteer from after lowering a car is bad alignment, creating what the quote said. Is this true, and could be why Jim hasn't noticed massive bumpsteer, because the alignment probably isn't that far out of wack? I don't really know, but alot of their stickies makes sense for the rsx applications, so I assumed this one was good also. The alignment is pretty close; forgot the numbers. Tire wear is even as well |
| dw914er |
Aug 28 2009, 12:33 AM
Then that's probably why...
when you drop a car, alignment gets off, and suspension parts get out of wack, like thetie rods work differently because of the angle, etc. This is from my understanding though, I could very well be wrong |
| SLITS |
Aug 28 2009, 08:17 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
HP Books - "How to Make Your Car Handle" - Fred Puhn
1981 - ISBN 0-912656-46-8 All the formulas, theories and headaches you could want! Steve Smith Autosports Publications - "Advanced Race Car Suspension Development" - Steve Smith 1974 - ISBN 0-936834-05-6 More of the same |
| jmill |
Aug 28 2009, 09:58 AM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
I like "Tune to Win" and "Engineer to Win." "Engineer to Win" gets a little more in depth as far as bump steer is concerned. "Tune to Win" might be a bit more applicable because your working with something already built.
| turboman808 |
Aug 28 2009, 10:46 AM
Wrote this long thing and then just made a diagram real quick. I need to install the 3d software already.
(IMG:http://i147.photobucket.com/albums/r283/turboman808/suspensiongeomertycopy.jpg) |
Lo-Fi Version | Time is now: 13th September 2026 - 07:31 AM |
