> E Brake Cable, Max adjustment at firewall ?
jim_hoyland
post Aug 27 2009, 10:47 AM
Get that VIN ?
I adjusted the rear calipers and reset the adjustment for the e-brake cable by the firewall--the one with a jam nut. It looks like most of the threads are showing on the pass side cable now. Does this cable need to be replaced ? or am I missing something ?
Phoenix-MN
post Aug 27 2009, 10:57 AM
How does the equalizer bar look inside by the brake handle cable? it should be fairly straight (perpendicular) to the two e-brake cables.
Paul
jim_hoyland
post Aug 27 2009, 12:17 PM
Get that VIN ?
QUOTE(Phoenix-MN @ Aug 27 2009, 09:57 AM) *
Paul
I'll check this afternoon
IronHillRestorations
post Aug 27 2009, 12:50 PM
I. I. R. C.
How much pad do you have? Adjust venting clearance first.
jim_hoyland
post Aug 27 2009, 12:54 PM
Get that VIN ?
Paul
Took pic with ebrake on. looks like they are out of balance. So, I'll loosen the pass side and take in the driver side.
Pads are fine, Venting clearance .004
I think I see the problem now, thnks for the tip
SLITS
post Aug 27 2009, 01:48 PM
"This Utah shit is HARSH!"
OH MY GOD I SEE RUST ON YOUR CAR JIM
Better look for another one. (IMG:style_emoticons/default/sawzall-smiley.gif)
(IMG:style_emoticons/default/av-943.gif)
- Lo-Fi Version Time is now: 30th April 2026 - 01:07 PM
