E Brake Cable, Max adjustment at firewall ? |
jim_hoyland |
Aug 27 2009, 10:47 AM
Get that VIN ? Group: Members Posts: 9,303 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I adjusted the rear calipers and reset the adjustment for the e-brake cable by the firewall--the one with a jam nut. It looks like most of the threads are showing on the pass side cable now. Does this cable need to be replaced ? or am I missing something ?
Phoenix-MN |
Aug 27 2009, 10:57 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
How does the equalizer bar look inside by the brake handle cable? it should be fairly straight (perpendicular) to the two e-brake cables.
Paul |
jim_hoyland |
Aug 27 2009, 12:17 PM
IronHillRestorations |
Aug 27 2009, 12:50 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
How much pad do you have? Adjust venting clearance first.
jim_hoyland |
Aug 27 2009, 12:54 PM
How does the equalizer bar look inside by the brake handle cable? it should be fairly straight (perpendicular) to the two e-brake cables. Paul Took pic with ebrake on. looks like they are out of balance. So, I'll loosen the pass side and take in the driver side. Pads are fine, Venting clearance .004 I think I see the problem now, thnks for the tip Attached image(s) |
SLITS |
Aug 27 2009, 01:48 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
OH MY GOD I SEE RUST ON YOUR CAR JIM
Better look for another one. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 11:10 AM |
