> SOT: getting paint off of tires
KaptKaos
post Aug 27 2009, 11:51 AM
Family
I got a set of tires from a friend. They're not bad and I'd like to use them BUT at some point someone (my friend) spilled paint on the tires. I am sure I will wear off the paint on the threads, but there is some on the sidewall.
Is there a safe way to take that off without compromising the rubber in the tire? It's home paint, not automotive grade.
TIA
tracks914
post Aug 27 2009, 11:54 AM
Canadian Member
Sandblast, fast and won't hurt the rubber.
turnaround89
post Aug 27 2009, 12:01 PM
ive heard a small amount of gasoline will remove it and a brilo pad, not sure about if it will compromise the rubber or not, but gasoline will probably get rid of it
zymurgist
"Ace" Mechanic
Can you mount the tire with the painted sidewall facing inward?
tradisrad
post Aug 27 2009, 12:58 PM
try a brush.
r_towle
post Aug 28 2009, 11:06 PM
Custom Member
steel wool.
iamchappy
post Aug 28 2009, 11:45 PM
It all happens so fast!
brake fluid...... scotch brite pad
gothspeed
post Aug 29 2009, 12:06 PM
Scotch brite and water.
Katmanken
post Aug 29 2009, 12:38 PM
You haven't seen me if anybody asks...
Curbs, I use curbs.....
Works every time..
Ditto the break fluid but be sure to clean it off after the paint is gone.
Keep away from the wheels if they have paint.....
Nana's_914
post Aug 29 2009, 05:25 PM
You could try MEK(METHYL ETHYL KETONE) and a rag if the less aggressive methods fail. Available at home depot and such.
MSDS=> http://www.jtbaker.com/msds/englishhtml/m4628.htm
- Lo-Fi Version Time is now: 7th June 2026 - 10:10 AM
