| ThinAir |
Aug 29 2009, 11:39 PM
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,572 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region
The stock 17mm master cylinders are NLA. 19mm MCs are running about $235. Automotion has a 23mm MC that's only $110. It says it's for 914s with upgraded calipers, but I'm wondering about using it with stock brakes. Anyone have any experience with these? There is no clue about whether it is ATE so I suspect not and so I also wonder about longevity.
| TravisNeff |
Aug 30 2009, 01:12 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
How strong are your legs? You'll lose all that leverage moving to a bigger MC. I wouldn't do larger than a 19mm unit - even with big/humungo brakes.
The 23mm units are mercedes MC's and you might have to dimple your A-arm cross member to get it to fit. |
| TravisNeff |
Aug 30 2009, 01:20 AM
Here you go
http://www.paragon-products.com/ShoppingCa...5%2E012%2E02APA under $90 bucks for a 19mm unit, states aftermarket - so I don't know who makes it. |
| ThinAir |
Aug 30 2009, 02:14 AM
Thanks, Travis. That's about what I expected to hear, but at that price difference it always makes you wonder if it should be considered. Anybody got experience with these URO MCs? My son has been pretty adamant that ATE is the only way to go.
| jmill |
Aug 30 2009, 11:47 AM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Brakes are last last place I'd cheap out on.
| ClayPerrine |
Aug 30 2009, 01:52 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
I have a 23mm master cylinder with Boxster calipers. I had the 944 turbo calipers with it, and it made for some really hard pedal pressures. It also made it really hard to modulate the brakes on the track. When I went with the Boxster calipers, I almost went back to a 19mm master cylinder, but I decided to wait. I like the brake feel with the 23mm master cylinder and the Boxster calipers. It is easy to modulate, and it stops extremely well.
With the 944 turbo calipers, Betty described my brakes as "70s Chrysler over boosted power brakes". I hesitate to think what it would be like with stock calipers......... But definitely not a good idea. |
| Cap'n Krusty |
Aug 30 2009, 02:42 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
What properties does a 23mm master cylinder have that makes it an "upgrade"? Increased pedal pressure requirements? Reduced ability to modulate the brake system with differences in your input? Cheaper? As for the sub-hundred dollar 19mm master cylinder, they're made in China, and are likely no better made than the fuel pumps AA sells. The difference here is a bad fuel pump means your car won't go. A bad master cylinder means your car won't STOP! You do the math.
The Cap'n |
| ThinAir |
Aug 31 2009, 01:12 AM
Thanks gang. I figured I'd stay with a 19mm ATE, but it's always good to know why it's the right choice.
Lo-Fi Version | Time is now: 30th April 2026 - 12:10 AM |
