| TravisNeff |
Aug 31 2009, 01:18 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
Do I have to drain the trans fluid first? I have a faulty switch and pulled on out of a spare trans (but I don't know if that one has been drained or not) and it didn't leak out a bunch of fluid.
Just want to know before I drain the fluid for nothing, or get a face full of that great smelling gear oil. |
| TravisNeff |
Aug 31 2009, 01:34 AM
I guess I should have searched a little more before posting.
I found some posts suggest that the switch is above the oil level of the gearbox. There was a suggestion that the plunger could be worn down and is not as long as it should be, so the switch is not engaged. A suggested fix (beyond replacing the plunger) was to use a similarly sized drill bit with the correct length as a replacement for the plunger. |
Lo-Fi Version | Time is now: 20th September 2026 - 01:47 AM |
