| casey944 |
Aug 31 2009, 02:34 PM
Member ![]() ![]() Group: Members Posts: 139 Joined: 10-August 09 From: nova Member No.: 10,654 Region Association: MidAtlantic Region |
Just replaced the warning switch in teh master cylinder... Any ideas? What should I look for?
Casey |
| TravisNeff |
Aug 31 2009, 02:38 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
You need to press the reset button on the side of the MC - right next to the plug. There is also a switch under your hand brake, when you set the e-brake the light will come on, when you release the brake it should stop the blinking - check to make sure that you are contacting the switch with the e-brake handle when you release it.
Lo-Fi Version | Time is now: 16th March 2026 - 09:38 AM |
