> What causes the Brake Warning light to flash?, 1972 1.7
casey944
post Aug 31 2009, 02:34 PM
Just replaced the warning switch in teh master cylinder... Any ideas? What should I look for?
Casey
Replies(1 - 1)
TravisNeff
post Aug 31 2009, 02:38 PM
You need to press the reset button on the side of the MC - right next to the plug. There is also a switch under your hand brake, when you set the e-brake the light will come on, when you release the brake it should stop the blinking - check to make sure that you are contacting the switch with the e-brake handle when you release it.
- Lo-Fi Version Time is now: 12th March 2026 - 05:39 PM
