4 Pages V < 1 2 3 4 >
> Saratoga Top came (mint cond.)
zymurgist
post Apr 21 2010, 12:52 PM
Post #21
"Ace" Mechanic
QUOTE(roadster fan @ Sep 8 2009, 06:59 AM) *
QUOTE(FourBlades @ Sep 7 2009, 07:19 PM) *
So someone start making a similar top now. It would be worth $400 for a new
one that was well made.
John
.....but cost you $50,000 in tooling just to get started. You would have to sell 2000 of em probably to get close to breaking even if you didnt pay yourself for development. Just a guess but that is probably why we don't see new ones in the works.
Jim
I assume that the original tooling was destroyed or its whereabouts are unknown...
EdwardBlume
post Apr 21 2010, 08:08 PM
Post #22
Man, those are nice... but $$$....
Joe Bob
post Apr 22 2010, 09:43 AM
Post #23
I googled "who makes the Saratoga top"....got a link to the x/19 crowd. They are making new ones. Maybe they got the molds.
Wear your foil hat....
Mikey914
post Apr 22 2010, 09:58 AM
Post #24
The rubber man
Different roof, but looks like they're tooling up to do one for the x/19.
McMark
post Apr 22 2010, 10:23 AM
Post #25
914 Freak!
If a Saratoga top owner could take some good pictures of the edges, corners and other manufacturing 'trouble spots' then I could get an idea of if production is possible. I was reading about some techniques the other day that would be applicable to this...
jim_hoyland
post Apr 22 2010, 10:35 AM
Post #26
Get that VIN ?
Lot's of research was done on the original molds; short story was they were tossed. Had one for several years, then sold it to Meng in Singapore. Hope he didn't have it on during the accident... (IMG:style_emoticons/default/sad.gif)
While I enjoyed the top, and really liked it when the weather was cloudy, it always seemed a little flimsy and storing it was not as easy as say the original top.
Several years ago, I approached a local marine plastics company that made winshields for yachts. After reviewing my top and the original top, they siad a better one could be made--start up costs were the issue.
It would be nice to see an updated design... (IMG:style_emoticons/default/smile.gif)
horizontally-opposed
post Apr 22 2010, 11:00 AM
Post #27
QUOTE(McMark @ Apr 22 2010, 09:23 AM) *
post Apr 22 2010, 11:01 AM
Post #28
post Apr 22 2010, 11:02 AM
Post #29
post Apr 22 2010, 11:03 AM
Post #30
post Apr 22 2010, 11:06 AM
Post #31
post Apr 22 2010, 11:08 AM
Post #32
Mark,
I *think* I've got them in high-res, as well. But I'd have to do some digging. Can bring them to you on a CD when I, uh, make it up there.
When do I have to get there by again? Slammed here...
pete
McMark
post Apr 22 2010, 11:43 AM
Post #33
914 Freak!
Pete, maybe I'll just come to you and your car can 'wear' the top that day and I can look at it in person. I'm actually more interested in the underside (where the seals are), although your pictures to illustrate a few things I didn't realize about the tops (such as the slope on the rear edge).
Oh, and you could come by on May 1 - Limo Build Day. (IMG:style_emoticons/default/cool.gif)
kropkom
post Apr 22 2010, 11:56 AM
Post #34
QUOTE(horizontally-opposed @ Apr 22 2010, 01:06 PM) *
Can anyone give me some ideas on what to do for replacement window seals for a Saratoga Top ????
post Apr 22 2010, 01:04 PM
Post #35
Ah, good plan — except I sold this one. And then I got another one from an old friend (who I think wants me to have a Saratoga top). (IMG:style_emoticons/default/biggrin.gif) So, yeah, I've got one to check out, and it was NOS when he got it (still very nice).
Seals are one of the biggest problems with the Saratoga top, right after the outer front edges, which don't fit flush and cause more windnoise than I'd like.
That said, nothin' beats a Saratoga top in some conditions and esp. around town. You feel like you're in a cockpit, so thin are the A pillars and top-of-side-window-seals.
JeffBowlsby
post Apr 22 2010, 07:17 PM
Post #36
These S-tops are only good when its too chilly outside to take the top off, that can be either moonlit nights, or clear mornings or days if its not too hot. On hot days fogeddaboudit, they make the cabin an oven, just take the top off or leave the stock top on as a sunshade if you don’t want a roasting.
I had an S-top a few years ago, sold it for G-note. It needed TLC when I bought it, I replaced the side ‘chrome’ plastic edging with standard black U-channel trim, the front edge and rear edge rubber weatherstrips (all from JC Whitney), painted the metal hardware and buffed out scratches in the plexglass. Some of the following are photos of my top which was in pretty good shape when redone, with its original side window top rubber, plus others I have right-clicked into my archive when found. I have seen a couple variants on the top hardware and weatherstripping from different 914 model S-tops, maybe reflecting improvements Ferrigan-Obrien made over time. The curved plexiglass panel may have been heat formed in a vacuum chamber over a mold which I think is possible to do low-tech, but needs R&D and the tooling. F-O did it for profit for years, so I bet it did not take an insurmountable investment for the tooling, it is standard technology. If someone were to invest the effort to make the mold and vacuum chamber and figure out the hardware/weatherstripping, I think it would be a hot seller if affordably priced.
It might also be worth considering just modding OEM tops and fitting sheet plex infill panels with rubber marine gasketing. The OEM tops with stock hardware/rubber are available, we each probably have 2-3 cores in our stashes, it’s a no brainer and it saves fabbing custom latches and hardware and weatherstrripping. Just cut out the entire center part of the OEM top panel up to about 2-3 inches from the edge. That edge is covered by rubber weatherstripping anyways, it’s an easy approach. Another possibility might be to use an OEM top to make a mold and cast, not vacuum form, new tops using a clear acrylic resin, then just mount the OEM hardware. 2 models could be made, one for the early, one for the late cars. This has the advantage of losing the S-top mounting blocks to create the depths needed at the edges and mounting points, a stock top has rain gutters and other strengthening profiles in it that the S-tops don’t have. My S-top flexed a bit off the car, because it did not have any real stiffening ribs to keep it planar.
That chromed plastic edging is a J-shaped piece that should be continuous on the sides all the way to the front and also around the rear edge, this one is modified, it probably broke off and the chrome easily ckinks up and delaminates and often looks bad. On the lower photos you can see the complex curvatures needed for the plastic and the common aftermarket U-shaped edging (black) that I used as a replacement.
JeffBowlsby
post Apr 22 2010, 07:18 PM
Post #37
Here you begin to see the edge/hardware details. This photo shows the lower front male edge, notched around the center block, similar to the OEM top, that is inserted into the front 914 windshield hoop recess slot. Also note the two rear mounts. These are simple thick cast acrylic black blocks glued to the plex top, with a modified common galvanized hardware eyebolts screwed into it to emulate the male prong on the OEM rear mount. All hardware the mounted into plastic had embedded brass threaded inserts. The eyebolt mods were to cut the eyebolt to a J-shape so the stock Targa latch hook on the car could grab it. The eybolt was so cheesy you could see the hacksaw marks and the lack of galvanizing at the cut surface.
JeffBowlsby
post Apr 22 2010, 07:19 PM
Post #38
This bottom photo shows the front lip which is nothing more than a 0.125 in. thick aluminum sheet powdercoated black. It is mounted on spaced cast acrylic blocks (black) that are glued to the plex top. The lip slightly curves to conform to the tops curvature. The front latch hardware on my top looked very much like OEM 914 latches but were not, they were custom. The rear mounts are as previously described – cast acrylic blocks with modded eye bolts. Note the side window rubber on this top, much lower profile than on mine, also this top is missing the rear edge weatherstripping that wrapped around the edge of the Targa bar. The 1st three photos here show an even different front edge detail it looks like a formed fiberglass Z-shape to match the tops contour, see later posts. There should be a foam rubber square gasket stuffed into that linear slot to keep wind/rain out. Looks better than the aluminum plate to my eye.
JeffBowlsby
post Apr 22 2010, 07:21 PM
Post #39
This top (hi George (IMG:style_emoticons/default/wavey.gif)) has the aluminum plate front lip, but has a different rear mount that looks similar in its polygon form to the OEM mounts. These photos are the best I have of it. It also shows how the rear end of the side window top rubber slants to conform to the slanted top edge of the stock rear side Targa rubber, and the rear edge weatherstrip.
JeffBowlsby
Post #40
This photo is the S-top front latch, it has a cast aluminum mounting base and seems slightly larger proportioned than the standard 914 latch, but otherwise pretty similar. Note the side window top rubber. On my S-top, this weatherstripping was 2 individual stacked profiles glued together and were a couple inches tall – ugly to my eye. The rubber shown here is similar but a little less bulky.
- Lo-Fi Version Time is now: 27th November 2026 - 01:42 AM
