New TPS circuit boards $35, Courtesy of Dave Sprinkle |
srb7f |
Sep 4 2009, 10:22 PM
Member Group: Members Posts: 157 Joined: 17-May 04 From: Roswell, GA Member No.: 2,077 Region Association: None |
I just want to give a shout out to Dave Sprinkle who is now making brand new TPS circuit boards for the 914 FI system.
This is seriously the best $35 I've spent on the 914 in as long as I can remember. It's a simple installation with the included instructions, and only took me about 30 minutes. After this, all of the jerkiness in the acceleration was gone just like that. A new TPS is NLA, and cost about $150+ last I checked when they were available. This $30 part restores the switch, so get one while you can. This will certainly keep me happy with my 2.0 until I have the time and $$ to convert to a 6! |
Dr Evil |
Sep 5 2009, 12:59 AM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Badass! Way to go Dave (IMG:style_emoticons/default/smile.gif)
saigon71 |
Sep 5 2009, 06:53 AM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Steve:
This is great news! (IMG:style_emoticons/default/aktion035.gif) What is Dave's "handle" on this forum. I would like to order one. Thanks, Bob |
jimkelly |
Sep 5 2009, 07:14 AM
now THAT is truly stepping up to the plate - wow
http://www.914world.com/bbs2/index.php?showuser=2943 |
saigon71 |
Sep 5 2009, 07:18 AM
now THAT is truly stepping up to the plate - wow http://www.914world.com/bbs2/index.php?showuser=2943 Thanks Jim. Just sent email. |
zymurgist |
Sep 5 2009, 09:27 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
I got mine yesterday. Thanks Dave! (IMG:style_emoticons/default/smilie_pokal.gif)
Now it's on my "to do" list for this long weekend. |
srb7f |
Sep 5 2009, 10:42 AM
Amazing, no doubt. I can do just about anything in terms or wrenching on these cars, but generating one of these circuit boards is definitely out of the prowess of an amateur mechanic like myself.
gothspeed |
Sep 6 2009, 11:22 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I need one of these ....... this will work on the 1.7 D-Jet also right ...... (IMG:style_emoticons/default/smile.gif)??
jsayre914 |
Sep 6 2009, 11:41 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
pm sent (IMG:style_emoticons/default/biggrin.gif)
914four |
Sep 6 2009, 11:51 AM
Senior Member Group: Members Posts: 510 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States |
It's a simple installation with the included instructions, and only took me about 30 minutes. After this, all of the jerkiness in the acceleration was gone just like that. I received my TPS circuit board and plan to install it today. The instructions do not say to remove the TPS. Step one says to remove the cover and step 2 is to drill out the rivet. I'm not sure it is possible to drill out the rivet while the TPS is installed. My questions are: 1.) Do you completely remove the TPS ? 2.) Do you have to recalibrate the TPS after this procedure? |
davesprinkle |
Sep 6 2009, 09:39 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
It's a simple installation with the included instructions, and only took me about 30 minutes. After this, all of the jerkiness in the acceleration was gone just like that. I received my TPS circuit board and plan to install it today. The instructions do not say to remove the TPS. Step one says to remove the cover and step 2 is to drill out the rivet. I'm not sure it is possible to drill out the rivet while the TPS is installed. My questions are: 1.) Do you completely remove the TPS ? 2.) Do you have to recalibrate the TPS after this procedure? Kelvin has correctly identified a weakness in the instruction sheet. (Thanks, Kelvin.) Yes, the first step should be: remove the TPS from the throttle body. Obviously, reinstallation will require that you follow the TPS calibration procedure. (My understanding is that it can be found on the Pelican site.) Thanks again for pointing this out, Kelvin. I'll update the installation sheets. -dave |
davesprinkle |
Sep 6 2009, 09:41 PM
I need one of these ....... this will work on the 1.7 D-Jet also right ...... (IMG:style_emoticons/default/smile.gif)?? Sorry, the 2.0 liter and 1.7 liter sensors are different. I am currently setting up to make the late 1.7 liter boards. Should be a month or so. How can you tell if you've got an early or late board? The early boards had wires soldered to the board. The late boards have spring-loaded contacts. |
srb7f |
Sep 6 2009, 09:52 PM
Well, I thought they were great instructions, but I didn't even open them until I got the TPS out on the workbench.
blitZ |
Sep 7 2009, 07:26 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I've been trying to sort out some poor idle and hesitation and think it may be my TPS. Is there anyway to determine if it is bad? Visually, it looks fine and I have calibrated it.
davesprinkle |
Sep 7 2009, 09:07 AM
I've been trying to sort out some poor idle and hesitation and think it may be my TPS. Is there anyway to determine if it is bad? Visually, it looks fine and I have calibrated it. The TPS has two functions: 1. Idle indication. The TPS has two contacts that indicate when the throttle is fully closed. The TPS calibration procedure takes care of this function. Your car will idle poorly if the ECU doesn't know that the throttle is closed. 2. Transient throttle detection. The serrated traces on the board act to detect changes in throttle position so that the ECU can add additional fuel. The car will have poor throttle response if this circuit isn't working properly. If you've performed the TPS calibration procedure and you still have poor idle, you should verify that your sensor wiring is OK. Check the continuity of the leads from the TPS connector to the ECU connector. |
jim_hoyland |
Sep 7 2009, 09:57 AM
Get that VIN ? Group: Members Posts: 9,294 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Nice update and follow through Dave. Tell me: how is the 1.8 L-Jet TPS different ?
zonedoubt |
Sep 7 2009, 12:30 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
Nice update and follow through Dave. Tell me: how is the 1.8 L-Jet TPS different ? It's not a wiper style, just a two-position contact switch. http://manuals.type4.org/ljet/tests/ljet13.htm |
jsayre914 |
Sep 7 2009, 01:11 PM
the paypal address you gave me is not working. can you please send me the correct address.
joe |
zymurgist |
Sep 7 2009, 03:05 PM
I installed the circuit board in Babydoll today and WOW, what a difference! No more bucking! This is the most awesome (and necessary) part I've seen in a long time. Thanks Dave! (IMG:style_emoticons/default/smilie_pokal.gif)
In other news, I'm so happy it came with 2 rivets. I promptly lost one in my kitchen and it still hasn't turned up. (IMG:style_emoticons/default/wink.gif) |
roadster fan |
Sep 7 2009, 03:06 PM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
OT but I have to ask. Are you the Dave Sprinkle I saw the other night on TV that is involved with Motoczysz?
I thought I recognized the name when watching "Birth of a racer" but couldn't remember from where. If it is you, what an amazing company! Jim |
Lo-Fi Version | Time is now: 15th May 2024 - 04:16 PM |
