master cylinder cap |
jimkelly |
Sep 5 2009, 07:33 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
both of mine seem to have a small hole in the dead center - when i put it back on after bleeding my brakes - a bit of brake fluid squirts thru the cap -- is this normal ??
jt914-6 |
Sep 5 2009, 07:44 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Mine has a small hole in it too. It must be a vent hole. If you get some out of it, I would say you may have too much fluid in. As a side note, my resevior has no hose for overflow....It has a place for one, but it is not tapped for a hose. I remember my '73 having a overflow hose, or am I wrong?
srb7f |
Sep 5 2009, 07:49 PM
Member Group: Members Posts: 157 Joined: 17-May 04 From: Roswell, GA Member No.: 2,077 Region Association: None |
I had this problem with a 19mm master cyllinder I bought new from PelicanParts, but it was the pressed cap type thing, not a "hole". I called them, and they sent out a brand new one right away. The new one was bone dry 11 years ago, and still was today when I bled the brakes to change my fluid today. I would replace it if I were you.
Lo-Fi Version | Time is now: 15th May 2024 - 08:47 PM |
