Steering rack spacers? |
mike_the_man |
Mar 12 2004, 03:55 PM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
How much do you have to lower the car before steering rack spacers are needed? I'm planning on lowering the front this weekend, maybe 1" to
1 1/2"s. Should I get the rack spacers, or not? Thanks, |
Zeke |
Mar 12 2004, 06:44 PM
Never left, but not right.... Group: Members Posts: 381 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None |
Absolutely. You can get some longer bolts and some washers and do the same thing. More than a bout 3/4 of an inch on the spacers/wahsers causes a problem with the steering shaft as it enters the bulkhead. Otherwise, you would use as much spacer as you lower the car. The rest (if needed) is done at the strut, either by raising the spindles or adding a special ball joint that is longer.
Lo-Fi Version | Time is now: 15th May 2024 - 12:58 AM |
