VACUUM HOSE LENGTHS, does anyone have the measurements? |
lagunero |
Mar 12 2004, 04:23 PM
Donkey Member Group: Benefactors Posts: 1,042 Joined: 8-January 04 From: orange county,ca Member No.: 1,531 |
Does anyone have the measurements for the hoses on a 1.7 ('73).
I found the diagram that shows the ID's but if that same chart had the length it would just swell. Just trying to maximize my garage time. Thanks |
anthony |
Mar 12 2004, 05:12 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
This question comes up so often...and there's never an answer.
Just get a tape measure. It will take you 3 minutes to measure all your hoses. You usually have to buy hose by the foot anyway so you'll be buying a little extra. |
lagunero |
Mar 12 2004, 08:40 PM
Well you're right about the "never an answer" to this one. I'll measure them and post the results.
Stay tuned for the conclusion of this episode of "Unsolved Mysteries". |
Rusty |
Mar 13 2004, 02:49 AM
Our own Dave Darling already did the work for you. Try this for a 73 2.0.
tod914 |
Mar 13 2004, 03:35 AM
I got a rough estimate of how much hose I needed. Then I pulled one piece off the motor at a time, and use it as a templet to cut the new hose from. Job went pretty fast. Only have lenghts for a 75 2.0 which are a bit different than what you need. Hope that's helpfull.
lagunero |
Mar 13 2004, 03:42 AM
Hey! Thanks alot! That's awesome. Mystery solved (at least for me).
JFJ914 |
Mar 13 2004, 08:12 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
Hmmm, there is something called a "PET" it can be found.................. . In it you will find all you are seeking..............
Lo-Fi Version | Time is now: 15th May 2024 - 06:19 PM |
